IDS Network Fail - No response on the UBP line Pin 3 at the DLC
Old Jan 23, 2020 | 07:05 PM
CTroxtell's Avatar
CTroxtell
Question IDS Network Fail - No response on the UBP line Pin 3 at the DLC
Doing a "Network Test" on IDS I get a "Network Fail - No response on the UBP line Pin 3 at the DLC" Anyone know anything about this error? Been trying to track down any gremlins in my truck. After reprogramming the PCM(PCM appears to of been pulled from a scrap yard because of the different tear tag), TCM and FICM to the proper tear tag I finally got my VIN to save in the PCM. Pulling up IDS OBD II Test mode 9 my PCM and TCM both show blank spaces. The VSM module fails as well but I'm not sure if line 3 communicates with that.
VIN now has my VIN shown, took 2 reprogramming sessions to get this to take.
Old Jan 23, 2020 | 11:13 PM
namnguye's Avatar
namnguye
I found some references that may help you:
https://forscan.org/forum/viewtopic.php?f=5&t=10700
Now you can fix NO Communication problems for 2008 Ford F150 bus network protocol using a voltmeter
Old Jan 24, 2020 | 04:40 AM
Yahiko's Avatar
Yahiko
The VSM could also be loading the network down.
It's been a bit but you may want to take a look at this PDF.
Old Jan 24, 2020 | 07:14 PM
CTroxtell's Avatar
CTroxtell
Just contacted @Motohead911 , he also has the Network Test Fail so this may be due to the fact this isn't a true VCM II or VCM II clone.
Old Jan 24, 2020 | 07:43 PM
Yahiko's Avatar
Yahiko
You may try disconnection various modules on the UPB network.
As a short would take that network out. Really any of the networks will have issues with a short.
Here is one thing I found when Googling : Ford F-series Network Fail - No response on the UBP line Pin 3 at the DLC.
https://www.autoserviceworld.com/car...work-problems/
Old Jan 25, 2020 | 09:06 AM
nocomm's Avatar
nocomm
I have been working on this for awhile now and have found many trucks with a similar problems.
Truck is 2004.5. It will start and idle but is derated. Im thinking its time for a tow to the Ford dealer.
Old Jan 25, 2020 | 05:48 PM
Motohead911's Avatar
Motohead911
I just checked mine, and I have a failure with the VSM and EATC (which is funny since I don't have an EATC). But I was able to get my info from OBD II Mode 9 Test.
Old May 16, 2022 | 09:25 PM
hossain210's Avatar
hossain210
2nd Gear
Hello
Do you solve it?
I have same problem between cluster and EATC
I ALSO DON'T HAVE EATC🤭
My problem came when I swap EMTC to EATC
i swap it several time but always return to EMTC Normally except last time it stock at EATC
Some times I got this code an cluster U1262 SCP DATA LINK FAULT
my vehicle is 2007 mercury monterey
Mistyblue101
Mar 17, 2017 09:43 PM
frmach
1997 - 2003 F150
Aug 12, 2012 06:21 PM
sprinklerguy
1997 - 2003 F150
Mar 29, 2007 06:25 AM
69isfine
1947 and Older Ford Trucks
Mar 17, 2004 07:27 PM
