Which side should I put the fuse? Solenoid/ start button
Old May 13, 2019 | 06:47 PM
hail destroyer's Avatar
hail destroyer
I'm hooking up a hot "start" button to crank the engine when I work under hood, a jumper switch for the solenoid.
I've got a 20 amp inline fuse, but I'm having a brain fart here. Which side should I attach the fused wire? Thanks!
(random Ford solenoid for example)
Old May 13, 2019 | 06:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
For an auxiliary start button, hook the fused wire to the battery terminal side and the other wire gets hooked to the small "S" terminal.
Old May 13, 2019 | 08:12 PM
hail destroyer
Thanks Mike!
ligito
Nov 13, 2016 07:35 PM
lurch460
2004 - 2008 F150
Jul 10, 2012 06:04 AM
fzeed
Dec 1, 2008 11:42 AM
rangershloman
Electrical Systems/Wiring
Jan 24, 2005 05:53 PM
russ10l
18
Jul 30, 2004 12:19 PM
