Not sure about your 99 but my 06 has a circuit on the fuse box labeled as "Cust ACCESS" it's a 10 amp fuse and it is a capped white wire with a blue or teal stripe towards the middle of the dash just hanging there - kind of behind the ashtray.
If I wire it to come on when I start, which wire? 99 F250
Look in your fuse box at fuse positions #9 & #10. They're supposed to be unused. If the terminals are there, you can access the HOT IN RUN circuit easily by plugging into and accessing the supply terminal.
Some seek fashion before form, others seek form before fashion, especially when there is an additional price tag involved. No right or wrong, all in the eye of the beholder and the pocket of the owner.
As the saying goes, different strokes for different strokers.
The ScanGauge might be a future option, as a tool with more features.
I installed a switch that will control both the voltmeter and a USB charging port, they both have LED's and I don't want them on 24/7.
