Recommendations for rear brake job on 2007 f350 DRW
Old Mar 10, 2019 | 09:57 AM
Shiloh51933's Avatar
Shiloh51933
I have a 2007 f350 crew can 8ft bed lariat DRW and I'm doing the rear brakes. I've done the pads previously on this DRW but this is first time doing the the rotors. I'm looking for recommendations on rotors, pads, axle seal and spindle nut socket. I normally get ceramic brake pads all around on all 6 of my vehicles but if there's something I'd be better off using I'm open to suggestions. When I replaced the front brakes I had to replace the calipers so I did everything including caliper brackets/pins. I used Motorcraft brake rotors, Centric brake calipers and Centric ceramic brake pads/hardware. Any suggestions would be great, thank you.
Old Mar 10, 2019 | 05:29 PM
TooManyToys.'s Avatar
TooManyToys.
I'm not a fan of ceramic fiber reinforced pads for this weight vehicle, but if you are happy with them put the same brand and level pads on the rear as you did the front. And if you're happy with those other parts then do the same too. The Superduty brakes from '99 through 2010 at least were all designed around having the same friction material formulation front and back.
Old Mar 10, 2019 | 09:45 PM
jmtbiggin's Avatar
jmtbiggin
Spindle sockets are dirt cheap on ebay
Old Mar 12, 2019 | 05:25 AM
Nice Work Truck's Avatar
Nice Work Truck
I put the Powerstop drilled set on my truck and like them. my truck has a daily weight of about 12k lbs.
Old Mar 12, 2019 | 06:40 AM
Shiloh51933
Really, I was eyeing those but I'd have to change the fronts to match. What about pads? How was changing out the rear disc, having to remove shaft/spindle?
Old Mar 12, 2019 | 08:05 AM
Shiloh51933
Do you happen to know the socket size or part #?
Old Mar 12, 2019 | 11:04 AM
jmtbiggin's Avatar
jmtbiggin
Mine is a SRW, Sterling 10.5. I have no idea what size your Dana 80 needs. Sorry
Old Mar 12, 2019 | 11:14 AM
TooManyToys.
Removing mass out of a rotor would not be my first choice.
Old Mar 13, 2019 | 03:07 PM
coolfeet's Avatar
coolfeet
I bought Ford original "Blue Box" brakes front and back on eBay. Never would have known about them until TooManyToys explained the difference between OEM and aftermarket parts. I cannot tell you if I like them or not as I have 15 miles on them. I had 2 frozen calipers. Maybe the van will get better fuel economy now that's it's not continuously braking. I hear so many lies about 6.0 getting 20 mpg.
Old Mar 13, 2019 | 04:01 PM
Nice Work Truck
You don't have to change them but it is better to. I have the heavy duty pads from them for the rotors. It is not to hard as long as you have a spindle socket. You will lose a little axle oil but not much.
Old Mar 13, 2019 | 04:07 PM
Nice Work Truck
I think this is the socket set that I have.
https://smile.amazon.com/Alltrade-64...s%2C150&sr=8-2
I got the Powerstop Z36 kit from Rockauto
https://www.rockauto.com/en/moreinfo...433533&jsn=671
Hammered29
Nov 18, 2017 05:11 PM
ab257z
Oct 31, 2011 07:58 PM
Hybris
1997 - 2003 F150
Nov 3, 2010 10:09 AM
350z
Dec 30, 2005 12:56 PM
MRBASS
Jan 11, 2005 09:27 PM
