BPD oil cooler with plow
Old Mar 6, 2019 | 01:36 PM
ithaca1230's Avatar
ithaca1230
Can you guys that plow and have a BPD oil cooler help me out with some advice. Our 2005 excursion I use for everything plowing towing and family traveling gets oil temps up to 230 when I have to drive with the plow on. the coolant temps get to 212 before the fan kicks in. I have read about the fan clutch for plowing and am wondering if this is the best option or should we add a fan we can just turn on with a toggle switch. Thanks for the advice
Old Mar 6, 2019 | 03:11 PM
Soler25's Avatar
Soler25
Just a thought. What about a little 6 or 8 inch electric fan, or two, mounted to the BPD radiator. You could wire these up to switches and kick them on when needed. You could use a variable switch Hi Med Low Off, or a thermostat that kicks on when the probe you put in the rad reaches a certain temp. Or a combo of both, thermostat with a Hi override.
Old Mar 6, 2019 | 03:23 PM
ithaca1230's Avatar
ithaca1230
Thats a option. was wondering others have done and how its worked.
Old Mar 7, 2019 | 08:09 AM
bismic's Avatar
bismic
Which BPD oil cooler do you have .... the remote located OEM one, or the air-to-oil cooler?
If manual operation of the engine fan would help, there is an easy mod to turn the fan on max with a switch.
Old Mar 7, 2019 | 09:02 AM
ithaca1230's Avatar
ithaca1230
I Have the air to oil cooler mounted in front of the radiator. When the fan kicks on it eventually cools down. Im sure if I was able to turn the fan on it would work. My question is has anyone used the clutch fan for plow package or installed a separate fan just for plowing. just wondering what works best for this situation. If the heavy duty clutch fan/plow package fan does the trick I would prefer that. If a remote fan works better with the air to oil cooler that I'll do that. Wiring the current fan to go on full when needed I guess could work it does drop the coolant temps very fast the oil temp starts to drop some but the fan kicks off before it gets low enough for my liking. just wondering what everybody else has done.
Old Mar 7, 2019 | 05:07 PM
Yahiko's Avatar
Yahiko
I was thinking that last night before going to bed and some how the post I had all ready with the diagrams went POOF.
Even setting up the override to test if more fan action would help might be a good step to try. If he finds that the temp drops
in the way he needs it to I would think that the plow fan clutch would do the trick. After all it is designed to move more air
when the plow is blocking a lot of the airflow when driving.
Old Mar 8, 2019 | 08:07 AM
ithaca1230's Avatar
ithaca1230
Thanks! Plowing season is almost over I hope and will prob start with swapping out the fan clutch. I have a coolant leak from someplace that we can't find and am working on that now. It only drips very little sometimes. Is we have to pull the shroud Ill swap the clutch then.
Mickey Bitsko
1997 - 2003 F150
Jun 9, 2018 09:24 AM
scottman70
Sep 30, 2010 07:25 PM
joe82ford
Feb 16, 2010 07:40 AM
scameron
Jul 11, 2009 02:09 PM
MarkMoore
Jun 28, 2007 11:34 AM
