Turn signal malfunction
77 f100 XLT Ranger.
Currently has an aftermarket steering wheel, which previous owner mentioned the auto cancel of turn signals doesn’t work with this one. The horn was also not working which I was able to fix by grounding the rag joint.
Then the my right turn signal keeps dying. I’ll replace the bulbs and it goes out after a few days. It starts by blinking very slow then the light stays illuminitaed on the the dashboard. But no turn signal is actually blinking.
Good job on the rag joint ground, I had to do the same thing to my '77.
Which bulb is burning out? Front, rear? The indicator in the dash?
The weird thing that just now started happening is that when the car lights are on, and the turn signals are NOT activated, the dashboard light of that malfunctioning turn signal is steady full bright on.
Im actually wanting to go back to the original steering wheel (which previous owner left with me)!
The issue with the light glowing, sounds like a fault in the TS switch itself …. just my guess.
I put a couple new switches in mine before I finally just cut the self cancel fingers off and installed a loud flasher that tic-tocks. With my seats, my now tight steering, the 14.5" wheel is just way more comfortable than that huge OEM wheel.
That little box to left of wheel with two buttons and switch is for Dana cruise control "control" as I didn't have a signal arm with switches to use. Set/coast button, redume button, on/off switch.
I have not yet had a need to ground the rag joint, but I'll keep it in mind.
