"Click" in steering
Old Feb 15, 2011 | 11:33 AM
nut1605's Avatar
nut1605
"Click" in steering
I have noticed on our 2009 F-150 there is an audible "click" (and you can feel it in the steering wheel) in left hand turns at about 1/4 revolution. You can also hear/feel the same thing coming out of right hand turns. It doesn't happen EVERY time, but pretty often. My wife had the service guy drive it when it was in for an oil change, and of course he didn't experience the same thing. I haven't looked into it myself yet, just wondering if anybody has any ideas what it might be or where to start?
Old Feb 15, 2011 | 06:28 PM
90F1505.0L's Avatar
90F1505.0L
You're not alone, I have the same issue
Old Apr 14, 2011 | 08:39 AM
XXX4play's Avatar
XXX4play
Same prob here with the 09
Old Apr 14, 2011 | 09:33 PM
awq134's Avatar
awq134
was your turn signal on at the time. if your turn signal was on and you turn beyond where the wheel was when you put the signal on it will ratchet to keep the signal on, and when you let the wheel return to the straight position the ratchet catches and releases the turn signal to the off position.
Just wondering if this is what you are feeling. if it doesnt' happen when you don't use the turn signal i'll bet that's what it is.
Old Apr 15, 2011 | 11:15 AM
duckhunter 51's Avatar
duckhunter 51
Checked mine yesterday no noise at all.
Old Apr 15, 2011 | 03:03 PM
XXX4play's Avatar
XXX4play
Mine does it at slow speeds turning the wheel left or right going slow like when you leave a driveway and its a clunk that you can feel in the wheel and sounds and feels like its a nuckle very close to the wheel and does it with or with out turn signals on. Truck does have tilt wheel and is a 2009
Old Apr 15, 2011 | 03:16 PM
murph1's Avatar
murph1
I have the same problem...only at slow speed like turning into my driveway or parking spot...not all the time but sometimes with the truck parked you can feel a little play in the wheel...not turning the wheel play but play if you just put a little pressure on the top or bottom of the wheel...
I haven't looked into it yet to see if I can find the problem,but it is getting more frequent..
I dred the thought of taking it into the dealer...
Old Nov 16, 2012 | 01:19 AM
1medic's Avatar
1medic
I have the same issue. Anyone out there get this fixed? If so what was the problem?
Old Nov 16, 2012 | 06:19 AM
XXX4play's Avatar
XXX4play
Never had mine fixed but don't seem to notice it anymore but since then I have had wheel bearings and ball joints replaced running 35's and 3.5" lift with 2" wheel spacers now also so if there was a problem I should definitely notice it now
Mtnhermit
Apr 30, 2016 12:57 AM
YellowXLT
Feb 23, 2016 09:15 PM
Liquid10Rider
32
Jun 14, 2015 08:30 PM
MattWis139
Feb 9, 2014 09:42 AM
Scratcher
Nov 28, 2010 08:58 PM
