door id plate
Old Jan 21, 2019 | 02:17 PM
dbgard57's Avatar
dbgard57
door id plate
Can someone decode this for me please
Old Jan 21, 2019 | 03:23 PM
F-ONE's Avatar
F-ONE
Series CodeF10F-100 (2 Wheel Drive)Engine CodeC292 CID 2v (135 HP @ 3800 RPM)Assembly PlantGChicago, ILConsecutive Unit Number440178Aug 1963
It's showing to be a very late 1963 F100
114 wheel base (shotr bed)
J Rangoon Red
f100
66b integral cab "uni-body"
A 3 speed standard duty
11 3.70 Ford rear
3345???
DSO..41 Chicago
Old Jan 21, 2019 | 03:43 PM
dbgard57's Avatar
dbgard57
door plate
Thank you,
You show J for color? Plate has a L. Can you clarify
Old Jan 21, 2019 | 03:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10 = F100 2WD
C = 292 2V
G = Chicago IL Assembly Plant.
440178 = 1963, assembled August 1963.
114" Wheelbase.
L = Holly Green.
F100 2WD; 5,000 lbs. GVWR
66B = Uni Custom Cab.
A = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
334541:
33 = Detroit MI Ford District Sales Office, where the original selling dealer ordered the truck from.
4541 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
F-ONE: The DSO code does not begin with 41, so it is not Chicago!
The COLOR code on the Warranty Plate is L, not J.
The 114" wheelbase does not decode to short bed.
1961/66: There was no way to know by any codes stamped on the Warranty Plate what kind of "back of cab equipment" (if any) these trucks came with.
Old Jan 21, 2019 | 04:16 PM
dbgard57's Avatar
dbgard57
door id plate
Where else might I find a vin# other than door
Old Jan 21, 2019 | 04:35 PM
NumberDummy
Where else might I find a vin# other than Warranty Plate on door
Hidden frame VIN stamped atop the right (passenger) side frame rail, either partially under the cab, forward of the cab or in the engine compartment.
The VIN on the Warranty Plate is known as the Warranty Number. FoMoCo said it isn't for title or registration purposes.
The reason they said this, was because it was too EZ to change. The usual reason:
1963/79: People replaced damaged left door with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
1961/62: Warranty Plate riveted to the inside of the glove box door. Change the glove box door, now the VIN won't match.
Old Jan 21, 2019 | 05:31 PM
James_Western_Canada's Avatar
A link with some info, and a pic of where to find the vin on your chassis
Decode Your '61-'66 Ford Truck VIN - FORDification.info - The '61-'66 Ford Pickup Resource
Highboy4x4
Dec 3, 2018 09:48 AM
Kirkb1
Dec 8, 2017 02:57 PM
S.earl869
Jun 29, 2016 11:05 PM
trossol
Jun 27, 2015 02:39 PM
Pacecar1986
Jul 17, 2014 08:18 PM
