64 F-100 Data Plate Information
I have a 1964 F-100 (2 wheel drive / short box) that doesn't have the original data tag, however I see Marti Auto Works reproduces them. I would like to get it as close to correct as possible, but I have some questions.
Warranty Number - F10CK480...
W.B - 114
Color - J or JM (I believe it was originally two-tone - red and white)
Model - F100 ( I saw F101 listed as well, but I've seen another 1964 2 wheel drive, short box that was F100)
Body - I see 81B listed for 61-66 Custom Cab and 99 listed for 64-66 Styleside Bed. This pickup is both a Custom Cab and has a styleside bed. I've also seen a number of examples with a letter / number in front of the 81 (E81, F81, 581, 281, ect.). How do I determine what would be correct? Is there a listing of the different interior codes?
Trans - F
Axle - I need to check the gear ratio.
Max G.V.W. - 5000
Net H.P. - 135
RPM - 3800
DSO - 51 (There's an emblem on the back from a dealer in Canon City, CO)
I got most of my information from here:
Didgey Specs 61-66
Thank you
Tim
W.B - 114
Trans - F
Max G.V.W. - 5000
Net H.P. - 135
RPM - 3800
Didgey Specs 61-66
Thank you
Tim
64 F-100 WARRANTY PLATE Information
I have a 1964 F-100 (2 wheel drive / short box) that doesn't have the original Warranty Plate however I see Marti Auto Works reproduces them (1964/65 US is the same).
W.B - 114
COLOR - J or JM (I believe it was originally two-tone - red and white)
MODEL - F100 ( I saw F101 listed as well, but I've seen another 1964 2 wheel drive, short box that was F100)
BODY - E81
TRANS - F
AXLE - I need to check the gear ratio and the type of rear axle.
MAX G.V.W. LBS. - 5000
CERT NET H.P. - 135
RPM - 3800
DSO - 51
W.B - 114
BODY - E81
TRANS - F
CERT NET H.P. - 135
RPM - 3800
DSO - 51
PIC (below): 1964/72 Ford truck parts catalog example of 1964/65 US Warranty Plate.
Warranty Plate riveted to the left door face below the latch.
1st line: Warranty Number: F10CK480XXX
2nd line:
W.B. 114
COLOR J = Rangoon Red or if tu-toned: JM: J = Rangoon Red / M = Wimbledon White.
MODEL F100 (F100 2WD, 5,000 lbs. GVWR) / F101 = (F100 2WD, 4,200 lbs. GVWR)
BODY E81 // E = Red Crush Vinyl & Red Check Stripe Woven Plastic / 81 = 81B Custom Cab.
TRANS F = Borg Warner T-98 4 Speed Manual Transmission.
AXLE = Could be a Ford 9" or a Dana 44 or a Dana 60.2 / 9" does not have an inspection cover.
If a 9" .. rear axle ID tag located at approx. 5 o'clock under one of the bolts that retains the carrier to the housing. By now, it too could be missing.
3rd line:
MAX G.V.W. LBS. 05000 (F100) or 04200 (F101).
CERT. NET H.P. 135 (292 2V)
R.P.M. 3800
D.S.O. 51 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
Thanks for the response and information.
I don't know if it's original, but the seat in my pickup appears to be just red vinyl.
What would the correct body code be for that?
It is a 9" rear end with 3.89 gears. So, the axle code should be 12. Does the tag on the rear end give any more information?
Thanks again
Tim
Thanks again
Tim
It's not original .. as the seat in my pickup was recovered in red vinyl.
What would the correct body code be for that? There isn't one, because this a non original upholstery shop replacement.
1964 Custom Cab as original (same info in post #2):
E81: E = Red Crush Vinyl & Red Check Stripe Woven Plastic / 81 = 81B Custom Cab.
WBG-F2 = 9" Rear Axle with 8 3/4" diameter ring gear / 3.89-1 / Large axle bearings with medium differential bearings/cups (MODEL code would be F101 w/4,200 lbs. GVWR).
3MD = Assembled the 4th week (D) of December (M) 1963 (3) / A = January, M = December, the letter I is skipped.
The other numbers is the assembly plant code.
GVA66FordF100
06-14-2017 11:27 PM
AlsRyd66
02-10-2015 08:26 PM
Pacecar1986
07-17-2014 08:18 PM
