Hey guys. It's good to see ya all, sorry I haven't been around much lately. I'll try and be around more often again. As most of you know if you are following Glenn's thread, I'm more than likely in the same boat as him. Hitman talked me into starting the tear apart of my truck tonight. I've got the radiator, fan, IC, bumper, OBA compressor and a few more things off. Should have no problem getting it pulled tomorrow. I'll be starting pretty early.
I plan on getting my injectors all freshened by Jim. My piston choice is going to be a set that are delipped and coated. Thinking of other things like a stage one cam and Travis suggested looking into a water to air IC like on the new 6.7. We'll see on those last things, I need to see what all I'm getting into first once I get it apart. It will be balanced also. This is all assuming that I will be able to rebuild what I have. Would have to be something pretty darn serious if I couldn't.
I hope to have it out tomorrow, and maybe start tearing it down then. Unless something major comes up I should at least know for sure what happened by the end of the weekend.
More to come.. I'll have to remember how to post pics on here. Man, it's been too long since I've been around.
From your description at the bottom, do you only have 160K on the engine? I believe Glenn said he has 185K on his, and it is currently being changed out due to catastrophic failure. These engines are supposed to last a lot longer than this. What's happening?
Glenn only has like 130 iirc. Only had the mods for 10-15k. Very sad.
good luck Darrin. Maybe it won't be terrible. I am on board with the piston choice if I ever get to building my other mill.
Yep, you're right. I just looked at a recent post, and Glenn's problem cropped up at 134K miles. Wow.
I believe the factory rated these engines at something like 500K before half of them were projected to need an overhaul. Many 7.3s were put into service in medium-duty vehicles, which is a hard life, and there are reports of some going 800K miles and a few reported even reaching the 1mm level. That's what I'm shooting for, but at 75, I ain't got enough years left. But there's hope: I've got a grandson I promised my ole '96 F250 to. He's 16 in high school. Hope he'll see it realize its full potential.
This guys have bigger turbos and making more power than stock, maybe that also was a contributing factor.
I did manage to hit 800k but after moding it the mill couldnt take it no more. It did last me more or less 100k with the mods, i did beat the hell out of my truck tho, problem started after an ilegal freeway race( never again)
According to some paperwork I found, mine got a reman and new turbo at 46,636 miles. Just about to reach 200k on the factory reman. Just goes to show that no matter how stable and reliable your manufacturing process is, there's always a few bad parts that will get through and cause catastrophic failure. We just only hear about the bad experiences.
Mine is actually at 170k now, but really still pretty low mileage. I didn't baby it, I didn't race it but I work the crap out of it. 30-40lbs+ of boost pulling 18k.
Well, its out. I got derailed for about 2 hours or so earlier today, so I'm glad Hitman talked me into starting last night. That's a lot of work for one man. I'm shot. Man, that thing is heavy. I left the motor mounts for last and then started lifting it out. I thought I must have something holding me up as it wasn't coming. Lifted a little more and it finally came. It's on the stand now, I'll start the teardown tomorrow. I don't see me doing a lot tomorrow, but I'd like to get the heads off at least and see what's up.
Glenn, water to air IC is something I don't know a lot about either, but I may look into it. I'm not going to rush the build. I don't see me getting it done before the end of the racing season so I'll just have to use Dad's open trailer and use 2 pickups to haul all my crap to the races. I think I have my 48' trailer sold, I'm looking at getting a new 53' one by next spring so I have to have this thing in tip top shape.
Hopefully tomorrow I'll have an update on what happened for sure.
Glenn, might as well get a 6.7 at that point. LOL!!
Darrin, looking forward to this one. I hate hear it, but I know it'll be even better when you're finished.
If this keeps up Bryon I just might get a 6.7. Only trouble is I would have to get a Divorce too! Seriously, I'm about to go nuts here but something happened today that I've never seen in a campground. This state park held an event called Christmas in July and what a feed, I'm stuffed, lol. Campers had decorations of Christmas out around their campers with lights and lawn ornaments.
I had given some thought to getting a new 6.7. Maybe that's what happened to me, I pissed my truck off! Now I have to fix it as it isn't worth anything this way so I will just keep running it for quite a while. The reason for a new trailer is I can't fit the golf cart and both cars in mine now, I need a few more feet of length. My thought was a new pickup or trailer by next spring. The pickup does work real good when running so maybe it's meant to be mine forever. Heck I only use it 5-6 months of the year on weekends only. Hard to justify 60k for a new one.
