Power cuts out and check engine light pops up when I accelerate
Old Jul 14, 2018 | 11:44 AM
Edale4's Avatar
Edale4
So since yesterday every when I go to accelerate about every other time It wont accelerate and my check engine light comes on till I tap the brake then the check engine light goes off and I get my power back any ideas
Old Jul 14, 2018 | 02:09 PM
Hussler's Avatar
Hussler
I'm thinking the IVS (idle validation switch) on the go peddle is flaky. If you push on the peddle and it does not switch positions the computer will ignore your foot pressing on the peddle. It's a two wire sensor on the peddle assembly, probably has lots of crud built up on it. Spray it with some contact cleaner as the part is no longer available and you would need to purchase the entire peddle assembly, kinda costly.
Really need a little more information on when this happens, driving normally or when taking off from a stop light?
Old Jul 14, 2018 | 02:10 PM
Bubba Jones's Avatar
Bubba Jones
Sounds similar to what was happening with me. There's a good chance one (or both) sensors in your accelerator pedal are going bad or the connections are getting corroded/dirty.
Take a look down at the accelerator pedal, you'll see one plug near the top go into a switch that is attached to a rod with a spring over it. This is your accelerator position sensor (sometimes referred to as TPS). Try unplugging this and spraying electrical contact cleaner in the plug and the switch. Also, just under that switch you'll find another plug that has a small button that registered if the pedal is being pressed or not. Again, clean that out with electrical contact cleaner and try and check over the wiring two these switches as best as you can.
Some people have had luck with simply cleaning those connections out, not me though.
I've also read on automatic transmissions, the wiring to one of these sensors likes to get chaffed up in the steering column next to the transmission selection lever (or somewhere in that location) and can intermittently ground out. It would be worth checking up there to see if those wires are starting to do that if cleaning the switches doesn't work out.
Old Jul 14, 2018 | 02:35 PM
867.309's Avatar
867.309
I added PIDs for the TPS and IVS after my deep water issue. I think you can monitor those. It didn't prove out a problem for me but it might work for you. My problem hasn't been back after the one incident.
I am coming up on my second oil change so I have put several thousand miles on my truck lately. I'm paying $2.74 for diesel, it's working for me.
Old Jul 14, 2018 | 02:40 PM
Bubba Jones
Not meaning to steal the thread but what exactly are PIDS? I don't assume you'd know but would I be able to use my Aeroforce Interceptor to look up those values? What are you using for that?
Old Jul 14, 2018 | 02:57 PM
867.309's Avatar
867.309
PIDs are live data from memory locations on the truck's computer. Using a OBDII adapter and a program like Torque, Forscan or CarGaugePro we can see the data coming in from the sensors and going out to the actuators.
Some of the other forums here use this a lot more than it seems this forum does.
https://www.ford-trucks.com/forums/1...nd-others.html
Old Jul 14, 2018 | 03:13 PM
7.3 forever's Avatar
7.3 forever
Just a possibility but the tin ipr nut can fall off and every time u excelerate the ipr selonoid slides back and hitting the brake makes it go back forward may be wrong but there’s a chance happened to me twice on two different trucks
Old Jul 14, 2018 | 03:43 PM
867.309's Avatar
867.309
A quick look at their website shows a lot of promise. It says you can do buzz tests and contribution tests with it. I'm not sure it goes all the way back to our trucks but it looks promising. If it works for our trucks, no truck should without one.
Technical Information
Old Jul 16, 2018 | 08:09 AM
Jarrett Campbell's Avatar
Jarrett Campbell
I know AE can see those values. I don't see why Aeroforce wouldn't be able to
Old Jul 16, 2018 | 11:13 AM
Bubba Jones
Yeah I may give them a quick call and see if I can get those values working (because they aren't on the stock list on my gauge when I went to add them to the values I monitor, but the website mentions TPS at least.) I'm thinking my IVS is intermittently failing so the pedal assembly you sent over may help. I hate intermittent problems, especially the electrical ones!
Edale4, have you made any progress on your issue?
GR8RN
Jan 17, 2018 06:06 PM
FordLou
1997 - 2003 F150
Jul 22, 2010 01:18 PM
hogdogs
33
Oct 8, 2007 05:38 AM
Jon Henry
1947 and Older Ford Trucks
Aug 13, 2005 02:17 PM
cybersufer
Apr 11, 2004 12:31 PM
