check engine light comes on
Old Apr 11, 2004 | 12:19 PM
cybersufer's Avatar
cybersufer
when the check engine light come on on my 02 f-250 psd and you push on the gas peddle while running nothing happnes. it dose not move or anything. if you turn off the truck and restart it works fine for a bit. during all this the truck is running . any help would be great.
Old Apr 11, 2004 | 12:23 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Trere are two switches on your fuel pedal. The Idle Validation Switch, and the Throttle Position Switch. One of those (probably the IVS) is likely going out. Neither switch is servicable individually, you will need to replace the pedal assembly. It runs about $125 from Ford.
Old Apr 11, 2004 | 12:31 PM
cybersufer's Avatar
cybersufer
ok cool well i have a extended warnity on the truck should cove it i think.
thanks for the help
