access panel on driver's side near dimmer swiitch
Old Jun 22, 2018 | 09:07 AM
sunbelt57's Avatar
sunbelt57
I'm try to remove the panel to the left of the dimmer switch held in by 4 large phillips screws. I'm installing sound deadner so I don't want to just cover it up. I'm having a hard time removing the last screw that's been on there for 40+ years. It looks like where a speaker would go. What's that panel for? What's behind it?
Old Jun 22, 2018 | 09:11 AM
brian1080's Avatar
brian1080
Nothing behind it. There is an optional vent that goes in that spot instead of the cover plate.
Trick for stubborn screws in sheet metal; seat screwdriver in the screw and tap it a few times on the end with a hammer. Should loosen it right up.
Old Jun 22, 2018 | 09:59 AM
sunbelt57's Avatar
sunbelt57
I used some PB-Blaster, tapped on it with a hammer and came back later and it came off.
Old Jun 22, 2018 | 10:15 AM
5851a's Avatar
5851a
If you have a panel you have AC, Non AC got you a vent as Brian said. If you take panel off clean out behind and below through it. Cowl drain.
Old Jun 22, 2018 | 10:44 AM
sunbelt57's Avatar
sunbelt57
It might come in handy on my next trip to Denver.
Old Jun 22, 2018 | 02:12 PM
brian1080's Avatar
brian1080
Here’s what it looks like
Old Jun 22, 2018 | 05:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on fresh air vent. 1st pic see 02039? That is the hole and 02104 is the panel.
Old Jun 22, 2018 | 06:51 PM
meangreen92's Avatar
meangreen92
There are six screws, and yes, they are a real chore. But you really need to unbolt your emergency brake pedal from the firewall, in order to access the two screws you can't see.
Old Jun 24, 2018 | 02:05 AM
mofoco1's Avatar
mofoco1
Keep the screws as the are hard to find exactly like that. I always take these from JY and install on all my AC trucks regardless.
Bootlegger's Deluxe
Oct 10, 2013 02:51 PM
johnday
2009 - 2014 F150
17
Feb 4, 2013 08:10 AM
Brady Phelan
Nov 19, 2012 11:53 AM
mabc926
Apr 28, 2011 06:41 PM
dallas lewis
1978 - 1996 Big Bronco
Feb 8, 2007 11:10 AM
