1978 - 1996 Big Bronco
Removing ECU
Old Jan 25, 2007 | 11:07 AM
dallas lewis's Avatar
dallas lewis
Removing ECU
I know that this is easier than I think, but how does the ecu come out??? I don't want to remove that whole panel under the dash to find that there is an easier way
Old Jan 25, 2007 | 12:55 PM
Kemicalburns's Avatar
Kemicalburns
you need to unbolt the harness from inside the engine compartment and then remove the driverside kick panel. not hard at all
Old Jan 25, 2007 | 03:28 PM
dallas lewis
I'm sorry, but I still don't know exactly what to do. When you say kick panel are you referring to the plastic insert or the potmetal looking piece behind it?? I know it's easy and that I can do it, I just don't completely understand it.
Old Jan 25, 2007 | 03:38 PM
bobstrat's Avatar
bobstrat
kick panel = plastic panel next to your left foot in driving position.(hood release handle pokes through it)
probably should disconnect the battery when you do it.
Old Jan 25, 2007 | 05:31 PM
lostin90s's Avatar
lostin90s
What year is this for ? My 93 up trucks it is more work to take out inside than loosening/removing bolts on fenderwell unscrewing harness for ecm and removing . I just did one in 15 minutes last month. Coarse I have done a couple good luck
Old Jan 27, 2007 | 02:30 AM
dallas lewis
It's for a 92 and a 93. It looks to me like I have to take out 12 to 15 bolts to do it. I'm not saying that I'm mechanically unable, I just hate to waste time doing stuff the wrong way.
Old Jan 27, 2007 | 04:58 PM
lostin90s's Avatar
lostin90s
engine compartment unbolt along fenderlip loosen any bolts on back splash gaurd . So can bow it down. Remove screws and harness plug bow well down slide out and reinstall. I just took one out of 93 parts truck yesterday. 0 degrees May take while to get all loose. Good luck
Old Feb 5, 2007 | 12:19 AM
dallas lewis
Just wanted to say thanks to lostin90s. Apparently the 92 and 93 are different than others. The EEC is under the hood, basically in the firewall. Thanks again all
Old Feb 6, 2007 | 07:55 AM
lostin90s's Avatar
lostin90s
No problem How did it go?
Old Feb 8, 2007 | 11:10 AM
dallas lewis
It went good. I didn't have any trouble at all.
eds72
Jan 15, 2015 04:42 PM
Greasemonkey93
Sep 1, 2013 09:29 AM
DerrickC
Computer Chips & Tuners
Aug 22, 2004 09:04 PM
redlead3
Jul 29, 2002 12:58 PM
scooteraz
Jul 3, 2002 01:21 PM
