97 7.3 cranks no start no tach just about all things replaced
new Ipr,new cps 3 of them new gpr and glow plugs, vale cover harnesses new, new icp hpop level good wits comes on batteries good starter good.i do get smoke out of tailpipe New fuel pump, tanks have been dropped sending units redone. I don't know what next. Worked fine last summer sat for winter won't start
Crank with no-start AND smoke while cranking = Bad glow plugs or bad glow plug relay.
Or worse, some, but not all, of your injectors are good and trying to fire, but can't because the engine needs more than 2 or 3 injectors to fire it up.
If you've replaced the gp's and relay, confirm the relay is getting a signal from the PCM and it's actually working sending current to the glow plugs. There's part of the PCM that controls the relay that can go bad. Double check to rule that out.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
also icp and Ipr sensor are reading the right pressure
Did you confirm that the glow plugs are actually coming on?
__________________
Jonesd253
18
11-13-2012 08:38 PM
towinchebbies
13
02-12-2009 08:18 AM
