How to fix ext cab doors
Old 02-14-2018, 02:37 PM
brc777's Avatar
brc777
brc777 is offline
I bought a 2000 Ford F-150 extended cab a few days ago with the 4.2l v6. The rear doors want open. I know it is the cabes inside the doors are some how broken. The exact same thing happened to my Dad's Ford Ranger a while back. I know there are some do it yourself fixes. But you have to buy there products that do it.
What is the best fix diy it yourself or take it to someone and let them fix it.
I also had the common code for the 4.2 l. The P071. My truck has the high idle. Haven't had a chance to check vacuum lines or clean the MAF sensor.
Any comments would be gratefully appreciated.
Thanks,
brc
Old 02-14-2018, 10:43 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
Old 02-15-2018, 06:20 AM
brc777's Avatar
brc777
brc777 is offline
Thanks so much for the videos. That is why I love this forums. You guys are great.
Thanks,
brc
Old 02-15-2018, 05:51 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
your error code is missing one digit.. P071X ??
Old 02-15-2018, 07:07 PM
brc777's Avatar
brc777
brc777 is offline
Sorry I meant P0171. I believe that means bank one
I hope it is not a intake manifold leak.
Old 02-15-2018, 09:29 PM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Maybe? certainly a vacuum leak. Have you check the Elbow on the rear or fire wall where the PCV is plumbed into. That's the biggest culprit but check every where on the vacuum lines. there is also a plastic vacuum canister behind the battery in the fender that is not always checked . You might have t make a smoke machine. There is several DIY smoke machines on You tube as well.
Old 02-16-2018, 07:40 AM
brc777's Avatar
brc777
brc777 is offline
Thanks for the info and advice. I am already up early this morning looking at the forum and youtube videos on how to locate and replace the pcv valve.
With my truck having a high idle does that lead it to a more specific problem?
I have seen some replace things that cause the idle to fluctuate back and forth and they were told it was something specific like a pcv valve. Just wondering.
Thanks,
brc
Old 02-16-2018, 05:07 PM
brc777's Avatar
brc777
brc777 is offline
Thanks for the videos. I followed the steps in the video. I used plastic zip ties. Thanks again
Old 02-16-2018, 05:14 PM
brc777's Avatar
brc777
brc777 is offline
I cleared the check engine light with my ob2 scanner. So far the check engine light has not come back on yet. Hopefully the previous owner did the work for me. I hope .
brc777
1997 - 2003 F150
16
05-06-2018 11:31 PM
crazyredneckanyhow
WTB - Parts & other
11-09-2012 09:21 PM
Andy's Beast
1999 to 2016 Super Duty
03-15-2012 11:00 PM
Quick Reply: How to fix ext cab doors
