I now have the 350 rear blocks and new U bolts. Before I get all excited and tear into this are there any other parts to be concerned with, like shocks, brake lines, emergency brakes, etc?
The only thing you might want to check on are the shocks. I know Rancho has different rear shocks for the 250/350, the difference in travel isn't much but there is some. I'm not sure if the OEM shocks are different or not.
I wouldn’t be surprised if you had to shim the carrier bearing a 1/4” or so since you have a 2 piece driveshaft. I had to add a shim to mine when I changed my blocks to get rid of the vibration on take off and I only went up an inch.
Shocks will fit only issue is carrier shim , you don't need it but it will vibrate the drive shaft when pulling out from a stop. Put the blocks in when you get a chance order the shim
Jeez, now you guys have me all worried. Jack and stands are no big deal, brake lines all appear to have planty of room, no sway bar, but do I need to buy a special shim for the carrier or just fab something up?
Brake lines will be fine don’t worry about them. You can order a shim kit or you could make a few I don’t think you’ll need more than 2. I’ve made a few out of 1/4” plate steel that I have laying around. Here are the measurements I used 8 9/16 L x 1 1/2 W Hole center spacing 1" and 7 5/8”.
I'll try to crawl under my '03 F350 later today and take a look. I know mine is two years newer, but don't think much changed in that time.
I don't think the carrier bearing is shimmed from the factory. A true parts geek/gearhead may have better information, but from research I did a few months ago, the only "real" difference is the actual blocks.
So unless a gearhead chimes in with part numbers, I would not worry about shims as long as you do not get a new vibration when pulling away from a stop.
I just had my carrier bearing replaced at the dealer (last month), so the back of mine is still all factory parts.
Like i said put the blocks in . When you get a chance buy the shim and install . I have had 2 trucks i done this to 11 yrs apart in age both with same out come . Vibration is minor pulling out from a stop.. or just live with the minor vibration anddont install a shim. All the lift companies sell them.
This is horrible advice, don't do it. U bolts are a one time use item, the threads deform to lock the nut once they are torqued to spec. Either put the shims in to begin with or plan or replacing the u bolts again when you do the shims. If someone can't afford ~$40 in u bolts to do the job safely, maybe they need to start rethinking modifying thier vehicles. It's just hack.
also expect rear to be more bouncy due to less gas compression in your nitrogen charge shocks. raising the truck 2 inches extends the shock shaft length 2; and at the state there is less gas compression. this wont effect expansion dampening but will effect compression dampening. that's why they sell the extension adapter. ...the adapter restores the shocks gas compression.
The shim goes between the carrier bearing and the frame. No need to take the U bolts loose to install it. What he is saying is put the blocks in and see if I even need a shim. I can always go back and put one in if I experience a vibration.
