Sponsored by: Real Truck
hangers and blocks
Old Apr 20, 2007 | 06:38 AM
getnbz's Avatar
getnbz
hangers and blocks
i have 8 inches of lift on now i want to put spring hangers and blocks in the rear on to get more lift. the shocks and brake lines want i want to know is do the hangers affect shock lengths and the brake lines will need to be longer but i know the front driveshaft will need to be lenghten but does the rear have to?
Old Apr 20, 2007 | 04:52 PM
ReAX's Avatar
ReAX
No, the shock mount should be constant so it really depends on how your shocks are spec'd if you need new ones. If your shock are for 6-8" lift, you will most likely need to get 8"+ shocks.
At 6"+ you start running into odd driveline angles. You might be able to get by lowering the center bearing, but I doubt it. In fact I would expect you would need a CV or double ujoint on both the front and rear.
Old Apr 20, 2007 | 05:25 PM
getnbz's Avatar
getnbz
sorry forgot to mention no center bearing here one piece driveshaft
Old Apr 20, 2007 | 06:08 PM
KrenzyRyan's Avatar
KrenzyRyan
You may need to lengthen it, unless the spring on it has enough travel to compensate.
Old Apr 20, 2007 | 07:01 PM
getnbz's Avatar
getnbz
spring? you mean on the slip yoke? if i need to lenghthen it is there a way to caculate how much i will need
Old Apr 20, 2007 | 08:28 PM
KrenzyRyan's Avatar
KrenzyRyan
Yeah, I don't know what its called haha. To answer your question, yes you can. You measure from where the driveshaft connects on both ends before and after puting the lift on. Thats what I did, and thats what driveshaft places recommend.
