Suspension advice
Old Apr 4, 2017 | 11:33 AM
Neil_dob942's Avatar
Neil_dob942
Suspension advice
Hey guys,
New on here and new to America. Moved over from the UK to the lovely South Carolina.
I've got myself a 1970 F250 CS 2wd and I've been busy on doing it up. Suspension is next on my list but I need help on my rear leaf springs.
It looks like there has been an add on at some point to the under side of the leafs. Can anyone shed any light on what this is? I assume it's to stiffen up the suspension. If I was to remove it will it lower the ride hight and make it softer?
Also I need new shocks are the ones fitted factory?
Any help would be appreciated
Right rear
Right rear
Left rear
Left rear
Left rear
Yeah needs some work I know.
Old Apr 4, 2017 | 01:00 PM
smoky_diesel's Avatar
smoky_diesel
Welcome to USA and FTE.
I would remove the add-a-leafs. Given their condition, removing won't change much. I think the outer clamp would have had to be farther out to do anything. I would just remove the clamp brackets and cut the leaf off with a cut off wheel. Don't think you will get u bolts off/on with the rust.
Those shocks are some sort of 'spring assist' (aka band aid). I would remove, it should soften ride somewhat.
Old Apr 4, 2017 | 01:50 PM
Tedster9's Avatar
Tedster9
Sometimes though, Joe Bloggs will add a leaf or two when the original pack itself is knackered. The rubber bushings in the shackles are junk by now too, probably. Spring packs contribute a lot to ride handling, and braking as well.
Nice rig!
Old Apr 4, 2017 | 03:40 PM
HIO Silver's Avatar
HIO Silver
The bracket at the rear of the leaf pack is what makes it a "Flex-o--matic" system.. OEM from Ford which effectively shortens the spring's length thereby stiffening it. Those brackets stay.
I'd remove the add-al-leaf under the leaf pack and the associated (square) U-clamps and plates.
Concur with the shocks... not OEM.
Btw, it'll still ride stiff but every lil bit helps.
Old Apr 4, 2017 | 04:42 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Are those add ons not to help with axel wrap from hauling heavy loads or flat out getting jiggy with it?
Old Apr 4, 2017 | 05:17 PM
BBX's Avatar
BBX
are those mounts for those coil overs? i assume removing them would soften the ride..
Old Apr 5, 2017 | 12:24 AM
Neil_dob942
Thanks for the advice, I think I will get the add-a-leafs removed, this truck is pritty much a commuter and the odd trash hauling but nothing of great weight. I won't be towing either as the rear tow bumper looks alittle rusty!!! Where it's bolted on.
Yeah my next purchase is gonna be new shocks all round, the ride is very bouncy and soft so I imagine they are shot. seen some good recommendations on here for brands so gonna get that sorted soon.
Thanks again guys, I've been busy with this truck since I've had it. Brakes, service, cleaning, electrics etc etc and I got a lot of good info from this site. I thought I was handy when it came to mechanics but this truck has tested me lol
sandymane
Mar 13, 2019 10:15 PM
peenhead
Dec 22, 2018 10:35 AM
mroth2008
Oct 6, 2015 08:22 PM
Curjo
Oct 19, 2014 12:29 PM
TNScrambler
Tennessee Chapter
Jun 26, 2010 08:44 PM
