Tightening rear U bolt question
Old Feb 1, 2017 | 01:28 PM
hoss73ford's Avatar
hoss73ford
Smile Tightening rear U bolt question
I just put a later rear end under my '66 F250. (1970 w/ 3.54 ratio, good gears, heavy duty brakes & positraction, boy did I luck out !) Any way how many foot pounds do any of you suggest I tighten the nuts to. The U bolts are new as I don't mess with re-using 50+ year old originals on something like this. The bed is off so I have easy access.
Old Feb 1, 2017 | 01:51 PM
'65Ford's Avatar
'65Ford
Which U bolts are you talking about? I can think of two sets involved in your swap...the pinion flange for the drive shaft/u-joint and the axle bolts that hold down the leaf springs. Good idea to replace both. I've never been able to get my torque wrench onto nuts for the pinion flange so I do those by feel. The axle bolts that hold the springs down I believe were around 140-150 lb ft for 9/16inch grade 8 bolts, drive a ways, and do them again.
I'll check my 1970 Truck manual tonight.
Old Feb 1, 2017 | 02:36 PM
hoss73ford's Avatar
hoss73ford
The axle to the leaf springs was what I meant
Old Feb 1, 2017 | 02:42 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Do you know now what size rod the Ubolt is? 9/16" 5/8"?
Old Feb 1, 2017 | 04:02 PM
hoss73ford's Avatar
hoss73ford
They are 9/16
Old Feb 1, 2017 | 04:50 PM
'65Ford's Avatar
'65Ford
Checked my 1970 shop manual for axle to leaf u bolts. 2wd F250 says 100-120 lb ft for 9/16 12 bolts. 4wd F250 says 150-190 lb ft
BTW, use hardened flat washers...not split ring lock washers.
Old Feb 1, 2017 | 05:57 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
^^^^^ What he said. If they are a 9/16" unplated than 100-120 ft lbs should be just fine.
Old Sep 15, 2017 | 06:18 AM
Nancy 1966's Avatar
Nancy 1966
Hello. I am new to all this and doing a frame off restore of a '66 F250. Thanks for the info on the ft lbs required for the u bolts holding the leaf springs. Is there any certain pattern I should follow in tighten all the u-bolts?
Old Sep 15, 2017 | 06:23 AM
Tedster9's Avatar
Tedster9
Evenly. Be sure to check torque again after 500 miles.
Old Sep 15, 2017 | 07:56 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
psquare7575
Aug 19, 2007 07:36 AM
Voh
Dec 24, 2006 03:03 PM
abcat12
Sep 4, 2006 08:24 PM
trusty79
May 19, 2005 09:38 PM
