u-bolts?
Old Sep 1, 2006 | 06:46 PM
abcat12's Avatar
abcat12
Question u-bolts?
I'm swaping f250 5 leaf springs onto my f150. it has a 9 inch rear and a broken 4 leaf setup. i dont think my bolts are going to be long enough to fit the bigger springs. they are only about 9 3/4" now. the problem is the bolts need to be 1/2" bolt 3 1/4" spread and will need to be about 10 to 10 1/2" long . i can get 9/16" ubolts that long but i dont think they will fit easily with out some serious reaming but i cant find 1/2" bolts that long? Is there anyone who sell longer 1/2" bolts or do i need to find a new plate on top of the springs?
Old Sep 2, 2006 | 01:56 PM
Piffery1's Avatar
Piffery1
I'd just drill out the holes on your existing plates if that's the only fit issue. You should be able to do it with a good 3/8" drill motor and 9/16" bit with a cut-down shank (or better yet a drill press).
Old Sep 2, 2006 | 08:51 PM
abcat12's Avatar
abcat12
it wont work because the bolts will interfere with the springs i thought about that. unless the bolts were drilled toward the out side but thats not real fun either break out the carbide bits. I guess it can be done but i was hoping for an easy way out but that might be what i have to do. thx
Old Sep 2, 2006 | 10:01 PM
tgore3's Avatar
tgore3
What about a rear block lift/lower kit and just used the bolts out of the kit. That should come with the same size bolts but longer.
Old Sep 3, 2006 | 09:11 PM
abcat12's Avatar
abcat12
who sels just the bolts?
Old Sep 3, 2006 | 10:26 PM
mercuryman54's Avatar
mercuryman54
Smile U bolts
A farm store called Rural King has a large selection of U bolts!! I would think most farm stores such as Tractor Supply Co. or Implement dealerships might have what you are looking for or maybe a 4 wheel drive shop.
Old Sep 4, 2006 | 08:24 PM
abcat12's Avatar
abcat12
i'll try TSC. if they dont i'll find a way to make it work
GermanMike
Aug 5, 2014 03:15 PM
Vin Man
Apr 19, 2012 04:27 PM
SmokinAce
Oct 17, 2011 08:58 PM
midcal48
Sep 9, 2010 12:53 PM
Cgarcia
Nov 5, 2004 04:50 PM
