replacement shocks for F250 4x4 with 6" lift kit
Old Jan 20, 2017 | 03:21 AM
highway90's Avatar
highway90
I am looking to buy replacement shocks for my 1977.5 F250 4x4. Its been a few years and the marketplace has changed.
Some quick internet searches found Skyjacker, Superlift, and Rough Country still offer shocks for a 6" lift using factory shock mounts.
Does any one have some good advice? or other options to consider?
Thanks.
Old Jan 20, 2017 | 07:32 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I get along with the Skyjacker ones on my 6" lifted 79 F250 just fine.
Old Jan 20, 2017 | 07:08 PM
maytea's Avatar
maytea
Shocks
I get a big company discount through Monroe shocks and still have no idea what would fit my 79 F250
I guess I need to start doing more research as well
It seams like it would be much easier then it turns out to be
Old Jan 20, 2017 | 09:29 PM
buckin69bronco's Avatar
buckin69bronco
What are the upper and lower shock mounts? I had a really hard time finding front shocks with stud mount top and bottom for a 4" lift. You may want to start looking at full spec sheets and go by top mount, bottom mount and length rather than someone's suggestion of a shock that is suppose to work. I went to into 4 wheel parts and they wouldn't even believe me about what I needed/had. I had to walk out when they told me they couldn't get me shocks until I changed the shock mounts
Old Jan 22, 2017 | 07:06 PM
highway90's Avatar
highway90
Front Shock. 1978 F250 4x4, 6" Lift
Rear Shock, 1978 F250 4x4, 6" Lift
Old Jan 22, 2017 | 07:13 PM
highway90's Avatar
highway90
Note 1: Yes, I plan to keep the original-factory shock mounts
Note 2: With the 6" lift it becomes a "custom shock" and normal parts stores do not sell anything close the the needed travel length, compression to retro fit. I checked several websites and the Monroe shock master data sheets.
Seems like Skyjacker, Super Lift, and Rough Country are the last providers of this item.
Option B. Change the shock mounts, custom fab so that a factory size shock from another vehicle would would and thus be available in any parts store.
Old Jan 22, 2017 | 07:14 PM
77&79F250's Avatar
77&79F250
Yes looks like a standard/OEM mount set up shock (stud and stud on the front) and (top stud and bottom bolt) on the rear.
The rear looks to me a custom leaf pack, because even on a Skyjacker 6" you have to reuse the OEM block and the rear block does not look OEM height.
I also see rear disk brakes and what looks like traction or ladder bar axle brackets, nice.
Old Jan 22, 2017 | 09:28 PM
BORDERBUM's Avatar
BORDERBUM
You wouldn't happen to have the skyjacker rear shock part number would you Rich? Been awhile since I ordered the ones for my other 79.
Old Jan 22, 2017 | 09:56 PM
HIO Silver's Avatar
HIO Silver
Ain't gonna matter much. It's still gonna ride like a covered wagon unless the springs are flexy.
Old Jan 22, 2017 | 10:12 PM
77&79F250's Avatar
77&79F250
Skyjacker part # for a 6" lift kit REAR shock. N8059 - Nitro Shock Absorber
Old Jan 23, 2017 | 04:55 PM
highway90's Avatar
highway90
Very good eyes.. Yes the rear springs are 100% custom. I had them made in 1998 by a spring shop. They ride like a lumber wagon. I see alot of companies out there now who offer "flexible" springs. Times are better..
Deaver Spring | Leaf Springs, Suspension, 4x4 Off Roading
1967 - 1979 F250 leaf springs - front and rear
Old Jan 23, 2017 | 05:16 PM
77&79F250's Avatar
77&79F250
Ck out Atlas...they have the option to delete the rear block all together. 1973-1979 F250//F350 4x4 Atlas SuspensionAtlas Spring Company
F350moneypit
Oct 3, 2017 05:51 PM
Jimmyrig
Mar 12, 2013 10:49 PM
crewcabdave
Oct 4, 2011 04:33 PM
jimbeam&coke
Oct 12, 2009 07:33 PM
chrisford410
Apr 6, 2009 11:55 AM
