Need help identifying part
Old Jan 19, 2017 | 06:56 PM
maribou912's Avatar
maribou912
truck is a 1977 f150 4x4 with a 400. It is equipped with ca emissions equipment so I have a hard time finding the right part often. Any ideas what this is, what it does, and where it should go. Rebuilt the motor and didn't label this little guy.
Old Jan 19, 2017 | 07:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's a distributor modulation valve, part of the emissions control system. Usually, but not always, attached to the right valve cover.
Old Jan 19, 2017 | 07:41 PM
maribou912's Avatar
maribou912
Thank you! Any idea where the vacuume lines that attach to it should head?
Old Jan 19, 2017 | 07:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I'll see if I can find a vacuum diagram.
Old Jan 19, 2017 | 08:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Older Chilton manuals have the 400 vacuum diagrams.
Old Jan 19, 2017 | 08:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Rich, I was having trouble finding a decent diagram.
Old Jan 19, 2017 | 08:23 PM
77&79F250's Avatar
77&79F250
I am here to help and I had that Chilton manual in the office. And I did not want to go up to the shop and drag out a regular maint manual. lol
Old Jan 19, 2017 | 09:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This is not a 12A170 distributor modulator valve, because there's none listed for any 1977/79 F100/350 w/a 400 (or 351M).
There's another valve that looks similar, basic number is 9D474. The original should have an ID number on it.
Old Jan 19, 2017 | 09:40 PM
maribou912's Avatar
maribou912
Numberdummy, the part number wore off. I tried to clean it to see the number with scotchbrite wore it right off
Old Jan 20, 2017 | 07:59 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, I missed the mark on that one .
9D474 is EGR solenoid vacuum valve.
Old Jan 20, 2017 | 08:36 AM
77&79F250's Avatar
77&79F250
Here is some talk about it and a pic of one on a 460. https://www.ford-trucks.com/forums/1...ying-part.html
Old Jan 20, 2017 | 08:50 AM
Aaron-71's Avatar
Aaron-71
This vacuum diagram is absolutely fabulous. Does the maintenance repair manual (or Chilton manual) come with a legend/comments section to describe the acronyms?
VCV? = Vacuum Value?
VCDV = Vacuum _______ Valve?
Air BPV = Air Bypass Valve?
Great post 77&79! Never knew I had a vacuum diagram in my old manuals... I'll have to keep an eye out for it when I go to reroute/repair all my missing vacuum lines.
Old Jan 20, 2017 | 09:22 AM
77&79F250's Avatar
77&79F250
Book is at the house, I am at work. I will check this evening got you. And will post up the date of that Chilton manual.
Old Jan 20, 2017 | 10:18 AM
Aaron-71's Avatar
Aaron-71
No rush!
I was just curious if anyone knew if there was a legend/descriptions listed in the manuals. Just helps me to understand exactly what I'm looking at lol
Old Jan 20, 2017 | 10:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
VCV=ported vacuum switch
VCDV=vacuum controlled delay valve
Air BPV=Thermactor air by-pass valve (differential without vacuum vent)
VRDV= vacuum retard delay valve
TVV=thermal bowl vent valve
V Rest=vacuum restriction
LCV=load control valve
TVS=temperature vacuum switch
