Washer Bottle Suggetions
Old Jan 18, 2017 | 10:37 AM
hurst1979olds's Avatar
hurst1979olds
I lost the lid to my washer bottle very early on in the ownership of my truck. I'm at the point now where I kind of need it. When I push washer button I can hear the pump Working so I put a little fluid in the bottle to see if it works. And I got nothing but I still heard the pump working.
I'm going to replace all the lines and blow out the nozzles. Should I just buy a new bottle, lid, pump. Or source a lid and hope I just had a clogged line.
Or would I be better off going with a universal style reservoir that comes with it's own pump?
Old Jan 18, 2017 | 02:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1TZ-17618-B .. Windshield Washer Reservoir-Less Pump / Reproduced
1971/73 Mustang/Cougar / 1971/79 Bronco / 1971/79 F100/350 (except 1971/73 with Power Pac [Onan Generator]).
Old Jan 18, 2017 | 04:38 PM
HoustonDave's Avatar
HoustonDave
Your washer hose goes from the pump to a small T or Y fitting on the firewall - unplug that and see if you have a stream when you hit the washers. Since you can hear the washer motor spinning - if you have a stream there your problem is probably plugged nozzles. If no stream, the impeller may have come off your pump and you will need to pull the reservoir and possibly buy a new motor (not a worry, they are like $15).
Old Jan 18, 2017 | 05:17 PM
scottscott's Avatar
scottscott
Contact me if you want a tank & lid, I have a couple, not sure if the pump is good. Shipping shouldn't be too bad, I'm in Pa too.
Thomscottson
Jan 31, 2018 02:19 PM
spaytons
Apr 12, 2014 08:46 PM
royzell
Electrical Systems/Wiring
Nov 28, 2007 03:56 PM
torquemeister
Jan 30, 2006 06:14 PM
uphill50
1983 - 2012 Ranger & B-Series
Aug 3, 2004 07:22 PM
