Shift lever pin
Old Aug 1, 2016 | 08:38 PM
dhglaser's Avatar
dhglaser
Shift lever pin
Hi Folks,
I need to verify a part for my 1971 F250 C/S 360cid 2wd automatic transmission.
I'm overhauling the steering column. The steering column is not original. It is a difference color from the interior of the truck.
In disassembled the steering column and I also ordered new parts from a mail order house in Kansas; and found that the old shift level pin does not match what was sent. Attached is a photo of the parts.
Note how the old part is a roll pin and the new part is has a steel spring retainer that bites into the aluminium shift collar when you push it through the shift lever.
So, here is the question? Has anyone seen this new style before?
The old pin is still good and I'm inclined to use it except that the hole in the aluminum shift housing is somewhat loose and egg shaped from accumulated wear.
So if there are any suggestions on how to fix the wear problem, I would be very receptive to suggestions.
-David
Old Aug 2, 2016 | 09:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
305093-S2 .. A/T Shift Collar Roll Pin - 3/16" diameter x 1 1/4" long / Obsolete
Applications: 1965/77 F100/350.
MANDERBACH FORD in Temple PA has 13 = 610-929-3683.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 13 = 800-476-9653.
Old Oct 20, 2016 | 12:03 PM
mrchad82's Avatar
mrchad82
I am curious as to where you got that brass looking pin. I bought a shift collar and its missing the pin and it looks like yours is the right type. I can't find that pin by itself anywhere.
Old Oct 20, 2016 | 12:54 PM
JEFFFAFA's Avatar
JEFFFAFA
Is this what you need?
Old Oct 20, 2016 | 01:05 PM
mrchad82's Avatar
mrchad82
I bought this and the top is 5/16 and the bottom is 1/4
Old Oct 20, 2016 | 01:25 PM
dhglaser's Avatar
dhglaser
I kept the old roll-pin. It is a 3/16 diameter.
On my steering column, the roll-pin is a press fit into the lever and a slip fit into the housing.
The holes in the housing were worn out so I drilled them out and pressed in some brass bushings.
-David
Old Oct 20, 2016 | 01:42 PM
JEFFFAFA's Avatar
JEFFFAFA
I just caught the D5TZ7228B part number on the box you posted. That's for a 3 on the tree not A/T. Ford originally listed that part number included in the box a 357479-s15 3/16" pin and a C8AZ7D439A 1/4" pin. Below is a Evilbay pic of the C8AZ7D439A.
Items in search results
Old Oct 20, 2016 | 03:18 PM
mrchad82's Avatar
mrchad82
[QUOTE=JEFFFAFA;16660229]I just caught the D5TZ7228B part number on the box you posted. That's for a 3 on the tree not A/T. Ford originally listed that part number included in the box a 357479-s15 3/16" pin and a C8AZ7D439A 1/4" pin. Below is a Evilbay pic of the C8AZ7D439A.
Thanks I think thatll work! Appreciate the expertise.
Old Oct 20, 2016 | 04:06 PM
JEFFFAFA's Avatar
JEFFFAFA
C8AZ7D439A:
Premium Listings
NOS Parts Ltd.
Recently UpdatedPart Number:C8AZ7D439ASeller:NOS Parts Ltd. - View ProfileDescription:PIN-TRANSMISSION GEARSHIFT LEVER PILOTPhone972) 937-2201
Price:Request PricingEmail:Send Seller Email InquiryQuantity:6Location:Waxahachie, Texas Map & Directions
Green Sales Company
Recently UpdatedPart Number:C8AZ7D439ASeller:Green Sales Company - View ProfileDescription:Phone 513) 294-8385
Price:Request PricingEmail:Send Seller Email InquiryQuantity:40Location:Cincinnati, Ohio Map & Directions
Miller Obsolete Parts
Part Number:C8AZ-7D439-ASeller:Miller Obsolete Parts - View ProfileDescription:PIN (1P3)Phone 607) 722-5371
Price:Request PricingEmail:Send Seller Email InquiryQuantity:11Location:Binghamton, New York Map & Directions
Dennis Carpenter Ford Restoration Parts
Part Number:C8AZ-7D439-ASellerDennis Carpenter Ford Restoration Parts - View ProfileDescription:NOS** PINPhone 800) 476-9653
Price:Request PricingEmail:Send Seller Email InquiryQuantity:8Location:Concord, North Carolina Map & Directions
RPN.com
Part Number:C8AZ7D439ASeller:RPN.com - View ProfileDescription:PINPhone 888) 666-0916
Price:Request PricingEmail:Send Seller Email InquiryQuantity:6Location:Mckean, Pennsylvania Map & Directions
McDonald Obsolete Parts
Part Number:C8AZ-7D439-ASeller:McDonald Obsolete Parts - View ProfileDescription:Phone 812) 359-4965
Price:Request PricingEmail:Send Seller Email InquiryQuantity:1Location:rockport, Indiana Map & Directions
AND
Klimesh Motor Sales
563-562-3241
xManderbach Ford
610-929-3683
kr98664
Oct 1, 2020 06:28 AM
Jeff64F100CrewCab
Jun 3, 2018 10:11 PM
tvliftcabinet
28
Apr 12, 2017 05:48 PM
cowboywanabe
Mar 4, 2012 08:56 PM
snowinindiana
May 22, 2003 02:42 PM
