Automatic shift lever troubles
Old Mar 4, 2012 | 07:04 PM
cowboywanabe's Avatar
cowboywanabe
Posting Legend
Everything is still working, but the pin that holds the shift lever in place is coming out. See picture below... the pin is coming out the bottom, but it is currently stuck. I've tried jiggling the column while pulling on the pin, also tried tapping the pin back up.
Anyone have any advice on how to get the pin unstuck?
Old Mar 4, 2012 | 07:53 PM
devino246's Avatar
devino246
Tried using a pair of channel locks to push it back in?
Old Mar 4, 2012 | 08:14 PM
dlburch's Avatar
dlburch
take a punch the same size as the roll pin and insert from the top to align the hole in the shift lever with the hole in the collar, then tap the rollpin up from the bottom.
Old Mar 4, 2012 | 08:43 PM
CalebJns's Avatar
CalebJns
Are you wanting to remove it or just get it back up into place?
Remember, if all else fails, use a BIG sledge hammer! or a small amount of gun powder, and a small blasting cap! J/K
If your trying to get it back in, I would say use a pair of channel locks. If your trying to get it out try the punch, tap it out...
Good Luck Either Way!
Old Mar 4, 2012 | 08:56 PM
cowboywanabe
Posting Legend
Thanks guys! I'm trying to get it back in, it's worked it's way out by itself. I have a history of breaking things and making small issues big problems, and wanted some opinions before I tried too hard.
(sledge hammer standing by just in case)
kr98664
Oct 1, 2020 06:28 AM
Jeff64F100CrewCab
Jun 3, 2018 10:11 PM
dhglaser
Oct 20, 2016 04:06 PM
ligito
Dec 9, 2013 10:47 PM
Earl
Aug 3, 2002 02:40 AM
