Sponsored by: Real Truck
crankcase vent
Old Jul 13, 2016 | 10:07 AM
schmidtz's Avatar
schmidtz
crankcase vent
what is wrong with this photo
What is wrong with the attached picture?
Old Jul 13, 2016 | 10:28 AM
schmidtz's Avatar
schmidtz
As assembled air would be pushed into the crankcase rather than drawn out.
Old Jul 13, 2016 | 11:05 AM
hav24wheel's Avatar
hav24wheel
Ya, that tube is installed 180* off.
Old Jul 13, 2016 | 11:23 AM
schmidtz's Avatar
schmidtz
Thanks for confirming that. when I turn it, it no longer lines up with the mounting bracket. the intake has been modified so I'm not sure if the part is original or after market. Its been assembled that way for years.
Old Jul 13, 2016 | 11:37 AM
hav24wheel's Avatar
hav24wheel
Hey, wait, where's that hose go coming off the bottom of it?? It looks like your crankcase breather on the valve cover is turned around sot the hose is off the rear of it... When it should come out the front, and than into a 90* hose into that plastic thing that bolts to the bracket.
Old Jul 13, 2016 | 11:53 AM
schmidtz's Avatar
schmidtz
Yes, as I said the intake has been modified. the hose at the bottom goes to a tank (pvc pipe) under the floor board where it is supposed to store fluid separated from the crankcase air. so the tube you see at the bottom does go back to the crankcase.
Old Jul 13, 2016 | 12:39 PM
schmidtz's Avatar
schmidtz
Again thanks for you input. I decided that collar with the pipe connected is factory and I put it back as in the photo. Re-thinking the airflow I believe it will pull from the crankcase due to the resistance the filter creates.
arthall
Flathead V8 & Flathead 6
Sep 14, 2018 08:28 AM
silverbullet6oh
Aug 28, 2016 09:05 AM
eatont9999
13
Jun 27, 2011 12:25 PM
spinella
Mar 31, 2011 07:27 AM
beanhead6D5
Sep 26, 2010 09:47 AM
