homemade tube steps
homemade tube steps
just finished a set of tube steps mounted in the stock location. 5" channel for the mounts, 2" square tube welded to the channel and 1 5/8" bent round tube for the steps. they are just in primer now. i'll take them off and paint them black. the hardest part was the compound angle where the round tube meets the square tube.
what do you think? i like them. i just have to remount my marker lights. i dont like the way they laid out. the mounting hardware for the steps got in the way. i'm going to add a peice of angle on top of the square tube in front of the pinch weld, this way i can space the lights out perfectly from end to end.
Those look nice, Ed! I just made myself some as well and I REALLY like them:
https://www.ford-trucks.com/forums/1...ml#post9913016
I tried to rep you, but I'm jailed... someone get him for me.
I had thought about the same thing, but I will say that the body is VERY stout... the flex was in the stock runners. But if you wanted to do that, I would use the body for the vertical support and use the frame for your horizontal support.
a little update. i did'nt like the way my lights looked. i had them mounted to the pinch welds. they were to recessed and because of the bolts that attach the steps to the truck the spacing was'nt perfect. so i made these contoured filler plates to mount the lights to. i spaced them out from the truck 1 1/4" and pre-wired them. heres some pics.
Cody_1948
12-21-2016 09:14 PM
mdula
40
11-02-2015 10:31 PM
IIISLACKERIII
02-01-2013 01:23 AM
