F250 - Door Hinge Replacement - Backing Plate Fell Off
Old May 15, 2016 | 02:41 PM
keg99's Avatar
keg99
Getting ready for a trip from Missouri to Montana in 3 days and had a broken door hinge. So I picked up a new one, got the bolts undone and, as the last bolt came out of the upper hinge,the backing plate fell down into the frame behind the dash.
Is there any trick to getting this backing plate out?
And then, how do I hold it so I can remount the door?
Old May 15, 2016 | 03:08 PM
fordpride's Avatar
fordpride
Pull the kick panel and e-brake pedal then you can reach inside.
Old May 15, 2016 | 08:31 PM
keg99's Avatar
keg99
Hey thanks!.. I did that and found the backing plate hanging just above the opening. Pulled it out and, with a lot of luck, prayer, cursing and and fortuitivness, got the hinge bolted on. Took most of the afternoon, but done. Thanks again. Whew. At least now I can travel with a door!!!
Matt1966
Feb 23, 2017 08:01 PM
supplementfacts
Feb 17, 2016 11:24 AM
big red c222
Apr 19, 2009 08:24 PM
27 Tall T
Mar 25, 2008 07:21 PM
Carlsonjw
Mar 11, 2003 01:00 PM
