If anyone has any thoughts would appriciate. Just trying to figure out if I need a drop pitman... If there there other mods that are necessary or would be better than a drop pitman.
I added a leaf to the front end of my 78 supercab which raised it a couple of inches and the pitman arm is just fine. I will note that the original springs were probably a little tired and it has a 460 in it.
Thanks for the replies and help. Yes it is a 1977.5 F250. It has a dana 44 front, and the steering arm is bolted to the knuckle on the drivers side, and the drag link connects to it from the pitman.
Guess I will try it and see, rather than spend any more $.
You may want to try one of the "lift blocks" that go between pitman and steering arm, I wouldn't recommend them for bigger lifts but should be ideal for you.
