The biggest one that skyjacker or anyone else makes (that i have been able to find) is for an 8" lift. If i have a 12 inch lift will it still work? What are my other steering options?
the biggest one that i know of for a 95 250 is a 6" spring not an 8.they make an 8" one but its for a truck thats another year.i got the 6" springs for my truck then i added a 3" body lift.you may get the 12" springs to work but they wont just bolt right up.you will have to fab all kinds of things.
when i was looking for springs i called competition leaf springs and asked them for prices on lift springs for specifically a 95 f350. He said they offer 10 and 12 inch springs.
you can use a 6" drop arm with a 10" lift. obviously not the optimal thing to do but will work. best thing to do is try and run a crossover steering setup. talk to cleatus, he had a OBS powerstroke with mucho lift and crossover steer. gotta have the knuckle milled and the drilled and then tapped for studs
Dont rely to greatly on that 6" pitman. Just use till you do cross over we dont wanna hear that something happened and another DOT reg had to be enstated.
