drop pitman arm how much lower?
Old Sep 3, 2014 | 09:08 PM
william16339's Avatar
william16339
hey guys again lol.. as you know by now prob, i have a 76 f250 highboy. the front is only 2 inches taller than stock ( lift spring) now.
i know stock leaf springs are 2 inches more arched than the 77.5-79, and i have a 79 power steering box (4x4) that im putting in , and im not sure how much i would need for a drop pitman? because of the 2 inch lift and the other 2 inches because of the high boy springs
i didnt make my bracket up yet and weld it..so i guess ill find out when i do it..but i kinda want everything now, this way i can just throw everything together after i plate the frame and bolt it up.
so not sure if a stock droppiman would work? or somthing 2-4 inches? or just do the swap first then find out? thanks
Old Sep 4, 2014 | 06:37 AM
somethingclever's Avatar
somethingclever
I think you will need a 4" drop but like they say...measure twice and cut once.
Old Sep 4, 2014 | 08:03 AM
NMFirstF2504X4's Avatar
NMFirstF2504X4
Have you considered a drop drag link? I'll have to look back at my notes, but with my 4" lift, but I recall the bottom of the drop pitman arm could end up pretty close to the springs. Plus the adjustment in drop drag links can come in handy.
Joel Cassell
Feb 16, 2025 03:27 PM
lasthighboy
15
Apr 29, 2012 09:59 PM
mjshagnasty
Feb 15, 2012 06:32 AM
quaallen
Offroad & 4x4
Mar 25, 2011 09:28 PM
starmilt
15
Feb 15, 2010 04:32 AM
