460 oil filter clearance question
Old Feb 18, 2016 | 03:44 PM
Rovernut's Avatar
Rovernut
1985 F-250 4WD with a 460.
The lower side of my oil filter is so close to the cross member that I can't slide a pine needle between the filter and cross member.
This seem so close too me, worn motor mounts?
What's the normal amount of clearance?
I think this is the mount I need
Amazon.com: Anchor 2709 Front Left Mount: Automotive Amazon.com: Anchor 2709 Front Left Mount: Automotive
Old Feb 18, 2016 | 08:08 PM
1985 Bronco's Avatar
1985 Bronco
Was the 460 swapped in?
Old Feb 18, 2016 | 08:53 PM
82F100SWB's Avatar
82F100SWB
You can rotate the adapter. It may be it has worked its way down over time.
Old Feb 19, 2016 | 05:25 AM
Rovernut's Avatar
Rovernut
No, all original.
I'll look in to that, though I have no idea what it should look like originally.
FWIW, I'm using Baldwin B2 which actually has a slightly smaller OD than the FL1A. 3.687 vs 3.780 based on what I can find for the FL1A.
Old Feb 19, 2016 | 04:58 PM
Rovernut's Avatar
Rovernut
Well, between the cross member on one side of the filter and a hose on the opposite side I can tell the filter mount hasn't moved any.
Do the motor mounts on these compress over time, like the 30 years this truck has been on the road?
Old Feb 20, 2016 | 06:11 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm sure they could.
Maybe you just have to clock the lower radiator hose on the pump inlet to get some more clearance?
Old Feb 20, 2016 | 09:22 AM
Rovernut's Avatar
Rovernut
Here're a couple of photos showing the limited clearance.
The first one, next to the cross member, makes me wonder about the motor mount rubbers. You have to look closely to see the edge of the cross member as it's in a slight shadow.
The second one makes me think the mount hasn't rotated down.
And yes, I know I have some oil leaks, those are on my to-do list when I have more funds.
Old Sep 12, 2017 | 08:57 AM
Rovernut's Avatar
Rovernut
Pulling the engine to do the clutch, heads and some seals.
Is there a preference on engine mount brands? Or brand to stay away from?
Or are they pretty much a commodity item?
Old Sep 12, 2017 | 10:59 AM
81F(ranken)100's Avatar
81F(ranken)100
I don't have experience with different motor mount brands, but I am an engineer specifically dealing with motor mounts for passenger cars.
The only difference I can imagine you would see from different brands is the quality of the finish, and accuracy of the mount assembly itself. It could be, perhaps, that one manufacturer does a bad job of metal preparation and adhesive coating prior to rubber injection - but that would only be evident by rubber/metal separation after time.
From what I understand, most of the time these "legacy" tools are transferred from the original production supplier to some "service" company who is willing to make aftermarket batches of parts. I could imagine that all these different "brands" purchase the motor mounts from the exact same supplier and put a different price tag on them - because none of these companies want to "tool up" their own aftermarket motor mount to sell to us ford-truck lovers - but that's just a guess.
And, yes, rubber will sag over time when under load. Typically all sag will have occurred within the first 5 years of use, and no additional sag will occur after this - only additional wear, cracking, deterioration.
Not that any of this matters to you! But I hope I could help!!
-Adam
Old Sep 13, 2017 | 04:37 AM
Rovernut's Avatar
Rovernut
Thanks, your theory about brand differences pretty much mesh with mine. I think this is something I don't need to over think.
BTW, not doing heads, not sure why I typed that, I'm replacing the exhaust manifolds with the other things mentioned.
At least I hope I'm not doing the heads. I am going to do a cylinder leak down test while I have it out and hoping I don't have a recurrence shipfitter's disease. I contracted it many years ago and tend to have outbreaks now and then.
EDsurvivor
Jul 22, 2016 04:53 PM
whiskey runner
Feb 10, 2016 02:52 PM
bigblockfever
Dec 25, 2012 08:20 AM
Biscuit
27
May 8, 2003 01:44 AM
Deadblow
Apr 21, 2002 09:17 PM
