Refilling 4 speed trans oil is a pain
Old Feb 14, 2016 | 10:47 PM
F250Rob's Avatar
F250Rob
Decided to change the oil in the 4 speed today, 1964 T98. Stuff that came out was black as coal and stank. Nasty.
After online research here and on other sites the Traveller All Mineral SAE90 Ford tractor transmission fluid from Tractor Supply seemed to be a good replacement. Threads here and elsewhere indicated GL-1 rated oil is safe for all the metals in these old transmissions. I know 50W engine oil was called for, but that's 1964 oil....not the stuff we have today.
Refilling that T98 was a pain. Next time I'm getting a pump of some kind. I managed to do it today by connecting tubing to a small funnel, pinching it off, filling the funnel with oil, lifting it up into place under the truck, sticking the tubing into the transmission, and letting it drain. One......funnel......at......a......time. Took forever, and oil was everywhere.
It sure shifts smoother. This '64 F-100 is growing on me, and will be a fun shop truck until the '56 is done.
Old Feb 14, 2016 | 10:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I keep a couple of the quart bottles with spouts and refill them. You can squeeze them and get more in quickly. There's just enough room to get the quart bottles in next to the trans.
Old Feb 14, 2016 | 11:15 PM
F250Rob's Avatar
F250Rob
Good idea there. The funnel and tube solution took a fair amount of patience.
Old Feb 15, 2016 | 07:59 AM
Rimrock F1's Avatar
Rimrock F1
I work at a boat shop and we sell a gear oil pump for refilling lower units on outboards and sterndrives. It's really just a condiment pump you might see used for ketchup and mustard, threads onto the top of the oil bottle and has a piece of clear hose slipped over the outlet. Put the hose in the filler plug hole and a few pumps later your done. Will work even if it doesn't thread onto the bottle but easier if it does. I use one for transmissions and for rear ends.
Old Feb 15, 2016 | 08:55 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I like to use the pumps but, have also just pulled the shift lever and poured it in from the top.
On my Tacoma automatic I bought a few feet of clear tubing that fit the fill hole snugly. I ran the hose up into the engine compartment, put a small funnel on it and poured in the fluid.
I have done it the hard way enough times to finally get creative and find a better way. The hard way sucks.
Glad you got it done.
Old Feb 15, 2016 | 10:00 AM
52 Merc's Avatar
52 Merc
This is why I love this forum. There's always one genius that's figured out the obvious that no one else ever thought of. Makes me laugh at myself for not thinking of it, either. Too bad I have the column shift.
Old Feb 15, 2016 | 10:07 AM
Scotty's 52 F3
I didn't think of column shift. Never had one. Takes me out of the genius category for not thinking of that.
Old Feb 15, 2016 | 09:53 PM
38 coupe's Avatar
38 coupe
I use an oil suction gun. Works great, assuming you can find one that isn't cheap junk.
Old Feb 16, 2016 | 12:25 AM
F250Rob's Avatar
F250Rob
I like the condiment pump idea...probably cheaper than something sold as an oil pump...
Old Feb 16, 2016 | 03:19 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
An old GO-JO hand cleaner bottle with pump (we all use the stuff) works great as a repurposed gear oil pump. You will be surprised how much oil they can move.
Old Feb 16, 2016 | 03:43 AM
Mixer man's Avatar
Mixer man
I have a Tulsa PTO on my transmission that has a forward and reverse (big sucker). There is just enough room to remove the filler plug, let alone stick anything else in there, so I drilled and tapped the drain plug 1/4 NPT and added a ball valve and plug. Now I easily fill through the drain with the aforementioned Go-Jo pump.
Old Feb 16, 2016 | 08:07 AM
cstempert's Avatar
cstempert
I usually just unscrew the shift cap and top drain plug, pull the shifter out and pour it right in. Can lay right there on the seat if you want
Says about 3-4Qts or something but usually starts to drain out the upper plug sooner.
Old Feb 16, 2016 | 08:49 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
The Shop Manual lists the transmission capacities in pints as follows:
3-Speed _____ 2.75 pints = 1.375 quarts
3-Speed HD __ 6 pints = 3 quarts
4-Speed _____ 5 pints = 2.5 quarts
4-Speed SS __ 8 pints = 4 quarts
5-Speed _____ 10 pints = 5 quarts
Old Feb 16, 2016 | 12:04 PM
49fordv8f4's Avatar
49fordv8f4
I have a 5 gallon bucket pump that I used to fill my T98. The fill is not in the best location. With a PTO, the PTO lever and hydraulic pump lever are in front of the fill plug, it is hard to get to. The bucket pump does make it a lot easier.
BTW, I read somewhere that motor oils do not have any additives that can attack yellow metals, so modern 50W motor oil should be fine in the transmission. I have an New Process 4 speed that has a tag on it stating to use 50W motor oil also.
Mark
ItsAFord55
Aug 6, 2011 11:50 PM
ltl_jrw
Oct 12, 2009 04:36 PM
powerstroke72
General Automotive Discussion
Apr 20, 2009 09:31 AM
Rich in CO
Jul 28, 2006 03:54 PM
hotshothauler
Oil & Lubrication
Oct 15, 2005 10:33 AM
