Ford 9" Shock Mount Location
Old Feb 15, 2016 | 04:52 AM
1950FordF1's Avatar
1950FordF1
I'm trying to decipher the correct rear axle year range for a swap into my 50' F1.
Previous post indicate the 57-72 F-100 axles are a direct swap (64 1/4" flange to flange).
Some I have looked at have a shock mount welded to the tubes. (67-72?)
What is the year range that the shock mount was part of the lower u-bolt plate?
Old Feb 15, 2016 | 08:59 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
You may have to cut the mounts off the axle you end up using and find or make some to work with your truck.
I swapped in a Dana 60. It was a bolt in deal except shock mounts and shortening drive shaft. I had to cut the mounts that were on the Dana and use the spring clamp type that was originally on the truck.
I'm sure someone that has done the 9 inch will chime in. Good luck with your swap.
By the way, there is a set of the lower spring plate mounts in the for sale section above.
Old Feb 15, 2016 | 10:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I used a 71 9". It takes no more than 10 minutes to grind the welds on the shock mounts, and relocate them or toss them. I'd rather get the newest axle, rather than buy a really old one just for shock mounts.
Old Feb 15, 2016 | 11:32 PM
1950FordF1's Avatar
1950FordF1
Thanks y'all'
I agree Ross the more I read not only the newest but the later F-100 housings were built stronger.
Another interesting journey. Ford built a lot of different 9" combinations based on vehicle weight and duty.
There are several good websites with plenty of information, here is one if you're interested in knowing more.
Ford 9-Inch Axles
Old Feb 16, 2016 | 08:19 AM
moejr's Avatar
moejr
I got lucky and found a 9 inch housing from a local bone yard........ I believe it's from a 64 f100 and the shock mounts matched without any modifications.
Old Feb 16, 2016 | 02:09 PM
48f1builder's Avatar
48f1builder
I cut the mounts off of my 9'' shaped them to fit the new location, and used the stock gas replacement for a 48 F1
Carbonarc
Mar 20, 2018 12:15 AM
Schuyles
Nov 6, 2012 10:19 PM
kb48
1947 and Older Ford Trucks
15
Jul 18, 2011 04:25 AM
DGMFORD
Oct 6, 2007 08:56 PM
Narwhal
Aug 10, 2004 07:56 AM
