1990 F150 4.9L High Idle Problem
Old Feb 2, 2016 | 09:47 AM
joemac1mn's Avatar
joemac1mn
Post 1990 F150 4.9L High Idle Problem
This truck will not idle down and has poor gas mileage. I have confirmed the IAC is operating. I checked it with a scan tool. KOEO(slow and fast): No Codes. KOER(slow and fast): 13; Cannot Control RPM During Self Test Low RPM Check. (I could tell the computer was trying to slow the idle, but it wouldn't slow.)
I checked the live data stream with these results.
ECT(V) 0.6; ECT(F) 194; Engine speed 1328, EVP(V) 0.3; EVR(%) 0; FuelPW1(ms) 6.4; IAC(%) 20; IAT(V) 0.7; IAT(F) 180; Loop Status Closed; MAP(hg) 10.0; 02SEN 1(V) 0.27; Spark 14; ST FTRM1(%) 8; TP Mode C/T; TPS(V) 1.0; V PWR(V) 14.1; V REF(V) 5.0
From what I have checked, the IAC at 20% is normal. Any suggestions, on what to do next, would be appreciated.
Old Feb 2, 2016 | 10:56 AM
subford's Avatar
subford
Smoke test for vacuum leak.
Old Feb 2, 2016 | 12:12 PM
joemac1mn's Avatar
joemac1mn
I have sprayed the vacuum lines, Intake Manifold area, and everywhere else I can think of, looking for signs of a leak, but no luck. I know that method doesn't work for detecting all leaks, but made the attempt, as I don't have the equipment for a smoke test. I'll see if I can get a tester.
Old Feb 4, 2016 | 02:10 PM
joemac1mn's Avatar
joemac1mn
I retested, with scan tool attached and set to ST FTRM1(%). It had showed me 8% when I first scanned, but the engine was cool this time, but showed a Closed Loop, and the percentage was from 1 to zero.
I then began spraying the intake gasket area, where it attaches to the engine and the readings immediately dropped to a low of -21, then slowly recovered when I stopped spraying. I had expected to see a rise in percentage if the intake manifold gaskets were bad. I didn't detect a change in idle, but tried this on another vehicle I own and fixed an intake manifold gasket issue.
My question is, at this time, does anyone know for sure what the negative numbers mean? I'm guessing that it might be the rich air is entering the exhaust manifold, but I don't like guessing.
Joe
Old Feb 4, 2016 | 03:21 PM
rla2005's Avatar
rla2005
In my opinion the negative Short Term FT value is pulling fuel out because the Long Term FT has not had enough time to adjust. That's been my experience with exhaust and vacuums leaks since I started using a Data Logger on my new to me 2005 Navigator.
Others may have a more experienced viewpoint.
Old Feb 4, 2016 | 04:15 PM
danr1's Avatar
danr1
The smoke test is the best way to find vac leaks if suspect there is any.
Simple enough to do and building a home spun smoker out of something very likely already have on hand is easy enough too.
If you don't own a compressor and pressure regulator that would be a snag though, you'll want to limit it to 1 or 2 psi behind the smoker.
I used a garden hose and slow but steady stream of water for years to check for vac leaks before putting together a smoker.
Works great, let engine and exhaust system get up to full operating temperature first. Take the hose and working low to high front to back allow small but steady stream of water to flow where suspect a vac leak, like along the valley gasket and head junction on each side of a v8.
Have someone watching tail pipe at the same time, if water finds a vac leak steam will immediately appear in the exhaust stream. Big leak lots of steam smaller leak not so much but there will be noticeable steam if you hit a leak with the water.
I've never burnt anything out never stalled one out and for example I've flooded injectors during the test engine running, using water it just plain works for finding gasket related vac leaks.
The vacuum lines are easily tested with a handy vac so no need to literally flood everything trying to check vacuum hoses with the garden hose.
Old Mar 20, 2016 | 11:50 PM
joemac1mn's Avatar
joemac1mn
Update on fix.
I was finally able to get a smoke machine to test the system. It was a bad intake manifold gasket and small leaks at the Egr and throttle body gasket. I put in new gaskets and a new Egr valve. Idles as it should and I'm still checking the gas mileage to see how much that helped.
Thanks for the advice. Nice to have it fixed.
hollenjoe
Modular V8 (4.6L, 5.4L)
Jul 28, 2011 08:55 AM
guitarnik
Nov 30, 2008 01:40 PM
gregcinboston
1978 - 1996 Big Bronco
Oct 24, 2006 11:09 PM
Paul_no
Aug 13, 2002 10:38 AM
island
Aug 3, 1999 01:29 PM
