strange idle condition
Old Nov 29, 2008 | 02:50 PM
guitarnik's Avatar
guitarnik
Question strange idle condition
i just replaced my intake gaskets. when i got everything put back together i filled it up with antifreeze and started it up. it ran straight up to 3300 rpms and just stays there. the only thing i can thing of is this, i cleaned some of the intake manifold with some gas and maybe some got into the manifold. i thought i drained it good but i guess not. the throttle is not open and all the seals are on and in place ???????????? anyone know something else that could cause this.
Old Nov 29, 2008 | 02:59 PM
danr1's Avatar
danr1
A pretty serious vacuum leak, or a bad IAC or unplugged maybe? (Idle air control)
If the idle was fine before you removed the intake you may have a gasket someplace leaking sucking air. Or missed reconnecting some/several of the vacuum lines.
Any gas you may have got in it cleaning it would have evaporated or sucked in a burnt up in the first few seconds, the idle would have quickly returned to normal once it was gone.
Old Nov 29, 2008 | 03:03 PM
guitarnik's Avatar
guitarnik
ok, now that i think of it. i think i busted two of those real fragile vacuum hose connected the the intake ill go check these right now. thanks nik
Old Nov 29, 2008 | 03:45 PM
guitarnik's Avatar
guitarnik
i fixed those vacuum lines and double checked all other hoses and checked seals. it still idles at 3300 rpm. checked all electrical connections. i dont understand. nik
Old Nov 29, 2008 | 03:50 PM
xltlariat87's Avatar
xltlariat87
sounds like the intake gasket didn't seal, allowing a vacuum leak.
Old Nov 29, 2008 | 03:52 PM
guitarnik's Avatar
guitarnik
thats what im afraid of. i was thinking the same thing, i guess ill go out and take it all back apart. oh joy, nik
Old Nov 29, 2008 | 04:04 PM
danr1's Avatar
danr1
Did you use any kind of sealer on the gaskets? If not that could be your problem.
You can check first with a garden hose, let water slowly run/puddle up over/around the gasket mating surfaces, if/when steam pours from tail pipe you found the leak.
I'd check it first, may just be the upper plenum gasket. I wouldn't pull the lower again unless I tested first and knew for sure it was leaking.
A little water won't hurt the injectors, but avoid direct drenching/submerging them with the water.
Old Nov 29, 2008 | 04:09 PM
xltlariat87
I agree, Iwould not pull it apart with out checking for leak first. It may be something else.
Old Nov 29, 2008 | 05:33 PM
guitarnik's Avatar
guitarnik
Got it
Turns out the fitting on the back of the plenum that the PCV valve hose goes into, came loose a few threads. Thanks for all the help guys.
Nik
Old Nov 29, 2008 | 05:38 PM
BCHauler's Avatar
BCHauler
That pcv fitting is a PITA to work with on these trucks for sure. I took it off once just to check it and it took almost an hour to put it back.
Glad you solved it.
Old Nov 29, 2008 | 07:41 PM
xltlariat87
glad you got it fixed.
Old Nov 29, 2008 | 07:44 PM
danr1's Avatar
danr1
Yea, and fixed without having to tear it all apart again!
Old Nov 30, 2008 | 07:30 AM
EPNCSU2006's Avatar
EPNCSU2006
Is it just me or does this sound like a really bad idea?
Old Nov 30, 2008 | 09:15 AM
danr1's Avatar
danr1
Sounds like a bad thing to do yea, but doesn't hurt anything.
Gives about instantaneous results that can be easily seen if one does have a vacuum leak.
Old Nov 30, 2008 | 01:40 PM
guitarnik's Avatar
guitarnik
thanks for all the help guys
Tim Inselmann
Jan 16, 2015 01:13 PM
MONAVIERONJON
Nov 3, 2013 08:24 PM
fusioncom
Apr 9, 2011 10:35 AM
scottbral
24
Mar 14, 2009 11:26 PM
dgassett
Dec 18, 2007 12:16 AM
