1978 - 1996 Big Bronco
High idle question
Old Aug 1, 2002 | 04:40 PM
Paul_no's Avatar
Paul_no
Post High idle question
Today for some strange reason, my engine was staying at high idle, even after warming up to normal temp. A couple of months ago, I replaced the idle air bypass valve with a new one, so I can't think why it is doing this. Anyone els have this problem?
Paul
Old Aug 1, 2002 | 08:34 PM
Flash's Avatar
Flash
High idle question
Paul, If you cleaned the throttle body while still on the truck, the solvent will destroy the gasket at the runners and manifold. If not, check the voltage at the idle air.
Old Aug 1, 2002 | 09:38 PM
Paul_no's Avatar
Paul_no
Well, I hooked the code reader to it this evening andit is giving me fault codes for the Throttle Position sensor, knock sensor, Thermactor, and "Loss of tach signal"??? I figured the TP sensor was on its last legs, so I'll check it tomorrow.
Old Aug 13, 2002 | 02:27 AM
VCSAR119's Avatar
VCSAR119
High idle question
I had the same problem.... I finally found that the upper intake manifold gasket was sucked into the intake.... I found this by spraying (of all things) carb cleaner at the joints, while the engine is running, if you notice the change, you have found the leak....
Old Aug 13, 2002 | 10:38 AM
RAzaRazor's Avatar
RAzaRazor
High idle question
hav24wheel
21
Feb 10, 2010 02:02 PM
Paul Welch
Apr 30, 2006 11:32 AM
paul76gs
Nov 11, 2002 03:32 PM
ryanstruck
Dec 19, 2001 09:01 AM
Paul Gayda
Events & Happenings
May 4, 2000 03:30 PM
