hi idle
Old Jul 20, 1999 | 07:00 AM
island's Avatar
island
hi idle
I posted a message a while back and got some good advise, thanks. But my 1990 F150 5L still idles hi after cleaning the throttle bores and now a new idle by pass valve. Even had a Snap on code reader on and could pull no fault codes from the computer. Does anyone know if a upper intake manifold gasket leak would cause this problem.
A propane bottle with long hose on passed around the outside of the manifold raised the idle level only so slightly but I couldnt get under the inside of the manifold that well.
Old Aug 1, 1999 | 10:04 PM
mikep's Avatar
mikep
hi idle
i had the same problem with my 91 5.0 and itwas the gasket,replaced the gasket and everything was fine,good luck
Old Aug 2, 1999 | 09:39 AM
Al Smith
Guest
Posts: n/a
hi idle
the upper intake manifold gasket is very likely to be the source of the high idle. It is fairly common.
Old Aug 3, 1999 | 01:29 PM
Phillip Guidry's Avatar
Phillip Guidry
hi idle
Red454sedgwick
Modular V8 (4.6L, 5.4L)
Sep 14, 2014 08:51 PM
dumpsterdan
3.8 & 4.2L V6
Jan 25, 2004 09:34 PM
InAlaska
Oct 3, 2002 06:49 PM
island
Jul 30, 1999 05:50 PM
island
Jul 24, 1999 09:33 PM
