302 in a 65. Can't find mount perches
Old Feb 1, 2016 | 03:45 PM
ffjoey's Avatar
ffjoey
Does anyone have any ideas on this? I have searched like crazy for info on a conversion kit but all I find is listed 64 and later. I assume that the crossmember for the twin I beam means using a cradle style kit will not work. I have seen most responses to this question is find a salvage yard truck but damn if I can find any anywhere. DVAP said they have some but $175 seems a bit steep. Nowhere else I have looked or called has them.
Old Feb 1, 2016 | 04:25 PM
jowilker's Avatar
jowilker
69-79 F series 302, 77-79 F series 351-400M will provide direct fit bolt up.
There was no 302 offered in a 65 so that could be the issue.
John
Old Feb 1, 2016 | 04:31 PM
daveengelson's Avatar
daveengelson
Topic came up recently: posting link may find helpful??
https://www.ford-trucks.com/forums/1...-question.html
Old Feb 1, 2016 | 08:29 PM
ffjoey's Avatar
ffjoey
Yes, I am aware that only I6 and FE were available in 65. I also know that any sbf 351m/ 400 perches 1969-79 will work. I just cannot find any
Old Feb 2, 2016 | 02:57 AM
Crop Duster's Avatar
Crop Duster
Run a search on car part. com there are lots of these trucks in salvage yards. Call the closest one and your done.Car-Part.com--Used Auto Parts Market
Old Feb 2, 2016 | 07:06 AM
ssandirene's Avatar
ssandirene
Go to the 70s forum and put an ad in the wanted section
Old Feb 2, 2016 | 08:24 AM
ffjoey's Avatar
ffjoey
Thanks guys. I will do both. So far not much luck with the parts finder website but I will keep trying
Old Feb 2, 2016 | 09:19 AM
greyhound's Avatar
greyhound
Smile mounts
Hello,
I have a 63 uni,put a 289 ford with c6 tranny in it.Bought a mount crossmember from speedway motors for a small block ford.Had to cut about 3 inches off each end of the new crossmember to make it fit between the boxed plates on the frame.The original ford motor mounts with long pin fit right to the crossmember.I boxed in the frame where my mount was going to be and welded it.Then sat the motor and tranny in with cross member and got it all lined up and welded it.I was very satisfied with how it turned out.
Old Feb 2, 2016 | 09:32 AM
ffjoey's Avatar
ffjoey
I think my I beam set up is going to be an interference problem for an engine crossmember. Maybe I am wrong?
Old Feb 2, 2016 | 04:58 PM
jowilker's Avatar
jowilker
I don't have for you but re-read post 2. The engine bay area is same from 65 to 79.
John
Old Feb 3, 2016 | 09:09 AM
theastronaut's Avatar
theastronaut
I'm pretty sure we still have the set that were in the '66 we restored. It had a 302 that we swapped out for the original 352.
Old Feb 3, 2016 | 10:15 AM
ffjoey's Avatar
ffjoey
Pm sent. Thank you
66FORDFAMILY
16
May 16, 2014 06:44 PM
Marine trucker
Jun 3, 2013 11:11 PM
smokey
Jul 11, 2012 10:03 AM
Bill W
Jan 26, 2007 08:23 AM
