64' 302 and T5 conversion. Help
Old May 15, 2013 | 11:06 PM
Marine trucker's Avatar
Marine trucker
I have a 64' F100 that originally had a 292 and three on the tree. I decided to try and do a 302 and T5 conversion. I am to the point where I need some suggestions about engine and transmission mounting. Does anyone know of a kit that would make my life easier? I have heard that since this truck has a solid front axle I have to offset the engine by 1.25" to avoid the original steering box, can anyone confirm that? Any information on this stuff or anything else having to do with this conversion would be greatly appreciated. Thanks!
Old May 17, 2013 | 09:44 AM
SweetBlasph3my's Avatar
SweetBlasph3my
I believe Summit Racing has a couple of mounting kits that I've looked at. I got a 64 that I'm going to be putting a 302 in but I'm not quite at that point yet. Plus I'm pulling it out of a donor truck and am hoping I can use those same mounts.
Old May 17, 2013 | 09:58 AM
Pickupmanx2's Avatar
Pickupmanx2
I just bought these for my 63,,, going to go with a 351C
Truck Parts and Truck Accessories
Old Jun 3, 2013 | 11:11 PM
Marine trucker
Thanks, Ill check those mounts out and see if they will work for a 302. I was hoping I could find someone who has done this before and was smart enough to keep track of measurements as to where the crossmember has to be on the chassis. It may be that I can just mount it exactly where the y-block sat. I guess Ill just have to find out the hard way and give a try.
I can't see why you couldn't use the crossmember from the donor truck. That may be the easiest way to do it.....just measure the frame width first and maybe you will get lucky. If the frame width is different get out the welder and extened it. At least thats what I would do...
Semper Fi pickupman
76fordo
Engine Swaps
25
May 4, 2011 12:34 AM
fordmanforlife246
Feb 25, 2011 09:02 PM
wills 64
Dec 31, 2009 11:56 AM
ddog210
Mar 3, 2009 11:13 PM
