A/C Clutch always engaging...
Old Jan 24, 2016 | 01:17 PM
afonda's Avatar
afonda
odd question, but the a/c clutch has always engaged randomly even though the a/c is not on and even now when the heat is on. is this normal?
Andy
Old Jan 24, 2016 | 01:25 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Don't think so, you could try the opposite of removing a shim and adding a shim to the clutch. If you are not familiar with this process, check out this video and instead of taking off a washer, add one that is the same size or one that will compensate for the lack of a shim.
You will probably have to go to Fastenal or maybe you can get lucky at HD or Lowes.
Alternatively, I think you can buy just the clutch plate and replace it. I am not sure if it comes with shims or not though.
Old Jan 24, 2016 | 01:26 PM
mightymoose95's Avatar
mightymoose95
if its on defrost the a/c will also be on. even if its on heat with a/c switch off. helps dry out the air.
Old Jan 24, 2016 | 01:59 PM
Sous's Avatar
Sous
FTE Emeritus
I did not know that, thanks for adding this information.
Old Jan 24, 2016 | 02:12 PM
Walleye Hunter's Avatar
Walleye Hunter
It has been a while, like six months or so that someone had a story on that. The title of it was something like, "A/C, always on unless it's off", and the consensus seemed to be that it always came on unless the whole HVAC system is shut off.
Old Jan 24, 2016 | 02:19 PM
Pikachu's Avatar
Pikachu
The A/C compressor will run in all settings except panel (vent) and floor.
Old Jan 24, 2016 | 02:55 PM
afonda's Avatar
afonda
ok.. I will check that out...
Yep.. i know it will run in defrost mode. But didn't think it would run in the other head modes. Thanks for the data...
Andy
Old Jan 24, 2016 | 03:18 PM
Walleye Hunter
Andy
There's one thing you don't have to work on, eh.
kdbbmanton
1997 - 2003 F150
Aug 9, 2006 12:17 PM
Brian0445
Mar 1, 2005 06:44 PM
94' Ford
Jul 6, 2004 12:34 PM
