56 F-100 hood dowell pin parts assembly.
Old Nov 15, 2015 | 06:52 PM
hooler1's Avatar
hooler1
What is the correct order when installing the hood dowell pin? Is it dowell pin,spring retainer cup, spring, then push it up through the dowell pin plate hole in the upper front of the hood, then use the two nuts to hold it and lock it in? Or do you do as above, but you leave one nut on the spring side of the dowell pin,then the other nut holds it all together through the dowell pin plate hole ? Not sure mine is right....
hooler1
Nov 15, 2015 06:50 PM
hooler1
Aug 26, 2015 10:16 PM
raytasch
Sep 8, 2013 07:17 PM
ssj7kids
Oct 26, 2011 09:04 PM
ghall
Aug 8, 2007 06:10 PM
