Sorry for the duplicate post!
Old Nov 15, 2015 | 06:50 PM
hooler1's Avatar
hooler1
What is the correct order when installing the hood dowell pin? Is it dowell pin,spring retainer cup, spring, then push it up through the dowell pin plate hole in the upper front of the hood, then use the two nuts to hold it and lock it in? Or do you do as above, but you leave one nut on the spring side of the dowell pin,then the other nut holds it all together through the dowell pin plate hole the upper front of hood?
Dr G
Aug 20, 2017 03:52 PM
hooler1
Nov 15, 2015 06:52 PM
hooler1
Aug 26, 2015 10:16 PM
raytasch
Sep 8, 2013 07:17 PM
RCsanjose
Jun 30, 2003 06:54 PM
