Larger tires
Old Oct 24, 2015 | 03:51 PM
kopy kat's Avatar
kopy kat
Larger tires
I'm thinking of going from my 275/70/18 tires up to 285/75/18 size. I'm sure that I'll have to have my speedometer reset, but my real concern is if I have to put the original size spare tire on in an emergency...will this mess anything up in the drive train?!
Anyone have experience with this situation?
Thanks, Larry
Old Oct 24, 2015 | 06:02 PM
MisterCMK's Avatar
MisterCMK
You will be just fine with whatever size spare comes stock.
Old Oct 24, 2015 | 07:19 PM
superrangerman2002's Avatar
superrangerman2002
No you will be fine for a short distance. Just don't use your elocker if you have it.
Old Oct 25, 2015 | 06:01 PM
Dakster's Avatar
Dakster
What superrangerman2002 said... And I would avoid locking in 4WD if you have to put it on the front for that short period of time.
Old Oct 25, 2015 | 06:41 PM
MisterCMK's Avatar
MisterCMK
I wouldn't. The tires are close to the same size. The front differential is open. Not seeing a problem here.
Old Oct 25, 2015 | 06:54 PM
Dakster's Avatar
Dakster
Tires are 8.4% larger... I like to play it safe. You can't make a tight turn in 4wd with both hubs locked. That tells me I would not want to drive a long distance with one tire larger than the other.
Just my opinion... in an emergency I'd drive in 4wd and take my chances no doubt.
Old Oct 26, 2015 | 03:43 PM
kopy kat's Avatar
kopy kat
I guess I should ask if anyone else is running 285/75/18 tires on a std. Non lifted F350...?
Old Oct 26, 2015 | 08:54 PM
Chad149's Avatar
Chad149
You'll be fine. Could go a little bigger if you want.
I'm running 295-70-18, plenty of room.
TCAS007
2009 - 2014 F150
21
Apr 2, 2019 08:34 AM
hurstcastle
Oct 9, 2008 09:35 AM
75 SuperCab
Aug 28, 2006 03:18 AM
RedStroker6
May 15, 2005 11:55 AM
Larry619
Sep 24, 2000 07:59 PM
