Injector suggestions?
Old Apr 3, 2015 | 11:54 PM
ved0303's Avatar
ved0303
Hey guys, my 97 is due for some injectors. I was fairly set on the "baby swamps" but then I talked to a guy who suggested I skip them and go for stage 2s, 160cc. He said he's run both and the stage 2s made the truck run much better/cooler. Since they empty so fast you can shorten the timing window. Any thoughts or suggestions? I'm going to do a terminator HPOP too either way. Are there any other mods that would absolutely need to be done for stage 2s? My truck is mostly stock right now; just intake, exhaust and tune.
Old Apr 4, 2015 | 12:03 AM
T_F_E's Avatar
T_F_E
You need an intercooler, and if your fuel system is weak at all e fuel. Automatic or manual? You can push the stock turbo to hard with those sticks...
Old Apr 4, 2015 | 12:06 AM
ved0303's Avatar
ved0303
oh yeah I should have mentioned, I am doing E-fuel too. So an intercooler is a must with the stage 2s? And it is a manual.
Old Apr 4, 2015 | 12:24 AM
fordman67's Avatar
fordman67
A clutch!!!! ,turbo, IC,exhaust,intake,proper tunes for the combo.
The stage 2s are a bit much for stock hardware otherwise..but they would run!
Old Apr 4, 2015 | 05:39 AM
427 fordman's Avatar
427 fordman
If your buddy tells you that the 2's run cooler than baby swamps, he's full of it imo. 2 trucks the same except those injectors, the 2's WILL be hotter.
Old Apr 4, 2015 | 08:03 AM
fordman67's Avatar
fordman67
When bill did his it ran good :-) but was smokey ,his new stock clutch would not hold and you will HAVE to be careful about over speeding the stock turbo and melting it down from egts as well. It will run...Much better tho with proper supporting mods.
If you plan on a t4 turbo setup and much better clutch down the road maybe go for it.
If you plan on staying stock turbo then go stage ones!!
Old Apr 4, 2015 | 09:24 AM
ved0303's Avatar
ved0303
what about a bolt on turbo like the Beans D66? I'd rather hold off on the T4 setup but its a possibility down the road but I wouldn't mind doing the D66. Anybody have any experience or insight on that?
Old Apr 4, 2015 | 09:46 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
There's not a real good vibe on the d66 around here. Most say it's borderline better than stock
Old Apr 4, 2015 | 09:47 AM
oldbird1965's Avatar
oldbird1965
My 96 has a D66 and it might be a 'hair' better then stock but for the money I wouldn't do it again.
Edit: Nike beat me, LOL
Old Apr 4, 2015 | 10:50 AM
fordman67's Avatar
fordman67
^ every person I have ever talked to said that..
I would guess maybe stage ones and d66 if not towing.I would save my cash for t4. Just be careful until then.
Glenn can tell you ALL about towing ! Listen to him is what I would do.
Old Apr 4, 2015 | 11:21 AM
oldbird1965
I'm still learning, learning, learning!
Must be a echo in here!
Old Apr 4, 2015 | 11:33 AM
fordman67's Avatar
fordman67
Or switch over to a SD type mount and do a gtp38r. That is better and if you look around SD takeoff parts are dang near free.I plan on that for my brothers truck. I have almost all of it and basically have nothing in it.
Much cheaper than t4 but not nearly the turbo options tho.
Old Apr 4, 2015 | 05:44 PM
ved0303's Avatar
ved0303
i would love to do a 38r. what are all the things you need off of a super duty for that?
Old Apr 4, 2015 | 05:45 PM
fordpride's Avatar
fordpride
2's can run cooler if set up correctly due to the larger nozzles and better atomization but before you spend the extra 7k to support 2's you have ask yourself if its worth it for what you do with your truck. Tuning Is the key here
Now if you drop in 2's and keep everything stock then you are asking to melt a engine.
Old Apr 4, 2015 | 06:49 PM
427 fordman
I hate to disagree with you Mike, but I have to somewhat, you are pushing quite a bit more fuel than ones. Then you have to burn that much more fuel. More fuel, more heat. Take Glenn and me as a comparison. Basic same setup. I'm way cooler than he is. EGT wise that is.
