Disc brake issue
Old Jun 9, 2014 | 12:22 PM
pd1808's Avatar
pd1808
Disc brake issue
Hi thank you in advance for any help. I'm new to the forum and just getting started with my new 195 F100.
I recently did a front brake disc conversion including a new booster and master cylinder under the cab. I also put Wilwood residual valves in the front and back. 10 pounds in the back and 2 in the front along with a proportioning valve in the rear. The truck already had a power brake conversion on the drums but I changed the booster and master cylinder anyway because at one point I thought they were bad.
The problem I'm having is the brakes are terrible the first time I drive it every day (daily driver). As I drive it they feel better and better eventually almost feeling like a new car. It seems to me like the lines are bleeding back to the master cylinder as it sits.
Anyone have any ideas to fix this issue?
Old Jun 9, 2014 | 01:26 PM
oldmerc's Avatar
oldmerc
oldmerc
Please don't be offended but are the residual valves in backwards ?
Old Jun 9, 2014 | 01:35 PM
pd1808's Avatar
pd1808
Not offended! It takes a lot more than that! I know that the rear one is fine, I'll crawl under later and look at the front one when I get a chance.
Old Jun 9, 2014 | 01:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I can't imagine you'd have any brakes if they were in backwards. My first guess would be that there is still air in the system. Do you have freeplay in the pushrod at the MC when the brakes are released?
Old Jun 9, 2014 | 05:11 PM
pd1808's Avatar
pd1808
Checked the other valve it's right. I checked and I couldn't feel any play in the push rod. It's hot like the surface of the sun here in Vegas so if I have to bleed them again it might just be easier to sell it!
Old Jun 9, 2014 | 05:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There SHOULD be play in the pushrod, it needs to let the piston come completely back.
Old Jun 9, 2014 | 05:38 PM
pd1808's Avatar
pd1808
Oh! So I probably need to adjust it a little bit to let the rod come out further?
Old Jun 9, 2014 | 07:23 PM
pd1808's Avatar
pd1808
So I adjusted the linkage on the booster rod and topped off the brake fluid (it was a little low). I didn't drive it due to the above mentioned firestorm outside but fingers crossed it works.
johnson.jeff.a
Aug 6, 2014 03:24 PM
talbotmatt
Nov 17, 2006 12:15 PM
65F100project
Aug 24, 2006 05:16 AM
talisker
Dec 28, 2004 05:11 AM
highboy1975
Apr 22, 2004 12:38 AM
