Another brake question
Old Nov 15, 2006 | 09:26 AM
talbotmatt's Avatar
talbotmatt
Does any know if I can use the master cyclinder that is on my 67 F100 and keep the system manual. The master cycliner is a 2 chamber one for front and one for rear.
Also would you still need the proportioning valve. I was just told from a local junkyard that I won't but still would like other feedback.
Thanks again
Matt
Old Nov 16, 2006 | 12:44 AM
hot428ford's Avatar
hot428ford
for what ?
You said use the one off what to what / I see a 67 but is it recieve are get ? yes the valve is needed for any drum to disc conversion .. but not for power drum ...
Old Nov 17, 2006 | 12:15 PM
dcbullet's Avatar
dcbullet
If you go to disk brakes you should not use the drum brake master cylinder. The disk brake master cylinder has a larger reservior.
Matt Mariani
1978 - 1996 Big Bronco
Jan 12, 2015 09:13 AM
fordboy_52
Kansas Chapter
Aug 9, 2011 08:08 PM
obey_your_master
Aug 16, 2006 07:08 PM
thesprocket26
Dec 25, 2005 08:38 PM
Beast12
Jun 5, 2005 12:13 AM
