New calipers, no brakes...
Old Mar 14, 2014 | 04:09 PM
texasjack's Avatar
texasjack
My rear calipers heating up while towing, so I replaced them. Thought they may be sticking.Now that I have new calipers on cant get a firm pedal after a dozen pump, hold,bleed trys! Do I need a scan tool to get air out? Whats the secret? ( searched brake bleeding, but this defies logic) Took calipers off, the lines sat open all night before I installed new ones, is it just air???
Old Mar 14, 2014 | 04:13 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Yes you need to bleed them for sure.
Old Mar 14, 2014 | 04:21 PM
Pikachu's Avatar
Pikachu
You have two people while bleeding the brakes, one to pump and hold while the other opens the bleed fitting, right? Sorry to ask a question so basic, but you didn't specifically say you did it that way . . .
Old Mar 14, 2014 | 04:26 PM
JOHN2001's Avatar
JOHN2001
On top of having two people you left the line unhooked all night..... Always start with the caliper the furthest away from the brake booster then go to the next closest one.
So obviously you'll want to start at the passenger rear then move to the driver rear. I do the fronts just to get rid of the old fluid up there too. Then passengers side front and lastly yhe drivers side front.
That's all there is to it aside from stopping just before the fluid stops shooting out. Repeat the process until it's under pressure and you don't see any more air.
Franko72's Avatar
Franko72
Molon Labe
Make sure both bleeders are at the top. It's common to get caliper that is marked wrong. If the bleeder is at the bottom you can bleed it till till your dizzy and frustrated and never get a pedal.
I went thru this not long ago even while trying with a Mityvac I could not get a pedal. If one caliper has a bleeder on the bottom just remove the caliper, flip it over and bleed it with a piece of wood acting as the rotor disc, or Mityvac it.
You'll get a pedal almost right away.
Old Mar 14, 2014 | 05:14 PM
texasjack's Avatar
texasjack
Yes, bleeding with 2 people..... Bleeder screw at bottom of caliper. ?
Old Mar 14, 2014 | 05:21 PM
JOHN2001's Avatar
JOHN2001
Half of your post makes perfect sense... The ohetr hlaf is lavenig too mnay qeutsoinos to be akesd. WTH are you tiryng to ask?
Old Mar 14, 2014 | 06:09 PM
Poolguy601's Avatar
Poolguy601
Both bleeders have to be on top
SpringerPop's Avatar
SpringerPop
Bleeder screws should be at the TOP.
On edit, Poolguy's correct!
Pop
Old Mar 14, 2014 | 07:47 PM
crop harvester's Avatar
crop harvester
Try not to pump a dozen times,it can sometimes contribute air bubbles, two or three slower pumps should due.If the fluid in the master cylinder get foamed up then let it sit or remove fluid & start over.
Old Mar 14, 2014 | 07:49 PM
texasjack's Avatar
texasjack
Well ,thats good news, they are installed incorrectly! Easy fix ...
Old Mar 14, 2014 | 08:07 PM
Franko72's Avatar
Franko72
Molon Labe
Bleeders at the bottom?
Old Mar 15, 2014 | 08:57 AM
tjc transport's Avatar
tjc transport
i ain't rite
i fill the master cylinder up, and crack the bleeder loose with a piece of clear hose on it going into a catch jar letting it gravity bleed. once air bubbles stop, close the bleeder and they are good to go.
Old Mar 15, 2014 | 10:28 AM
Tugly's Avatar
Tugly
You can see the bleeder valve on the top-right. This allows the air to escape out the top.
Old Mar 15, 2014 | 07:52 PM
cj45lc's Avatar
cj45lc
Yep gravity is your friend
connordanny
Jan 15, 2011 03:50 PM
quick35th
Jul 31, 2006 10:46 PM
snakethis69
1997 - 2003 F150
Nov 25, 2005 12:42 PM
Truckmano5
Sep 6, 2005 11:20 AM
Jays93XLT
1978 - 1996 Big Bronco
Jun 5, 2004 07:55 PM
