1978 - 1996 Big Bronco
Brakes won't work!!!
Old Jun 3, 2004 | 05:31 PM
Jays93XLT's Avatar
Jays93XLT
I just changed pads and shoes and when I finished up I noticed a small puddle underneath my driver's side wheel well. I popped the hood and my resivoir for the master cylinder looked like it overflowed (with the cap on) and it is full to the brim. My brake warning light isn't on but I have no pressure. I bled the rear's and no air came out. I can't loosen the front bleeders. I'd appreciate any help.
Old Jun 3, 2004 | 06:00 PM
jacque_strap's Avatar
jacque_strap
You probably got brake fluid out the top because the new pads were a lot bigger than the old ones so when you put them on it pushed the fluid back through the lines and ended up overflowing the resevoir. After you put on pads the brakes usually won't work until you pump the pedal several times. Don't know if this helps, but they are both common things that occur and you might want to check.
Old Jun 3, 2004 | 06:26 PM
Jays93XLT's Avatar
Jays93XLT
I pumped the breaks more than several times and still nothing, I'm thinking about going to get new calipers , I'm guessing the bleeder screws on those wont be bad. Thanks.
Old Jun 3, 2004 | 07:25 PM
andym's Avatar
andym
Calipers are expensive, and from the sounds of it, there isn't anything to suggest they're bad.
If you didn't open the brake system, and you didn't have any air in there before, you don't have any in there now.
Did you adjust the rear brakes? If they're not adjusted, the pedal will go all the way to the floor.
Old Jun 3, 2004 | 07:42 PM
Jays93XLT's Avatar
Jays93XLT
Adjusted?? I'm not sure what you mean.
Old Jun 3, 2004 | 07:58 PM
Abigbronco's Avatar
Abigbronco
Did you adjust the slack adjusters?
The rear is a drum brake system. Correct?
Did you put all the springs back on?
Old Jun 3, 2004 | 07:59 PM
AYoungblood's Avatar
AYoungblood
I just bought some last week... i think they were like 14 bucks... 25 w/o core.
Adam
Old Jun 3, 2004 | 08:30 PM
Jays93XLT's Avatar
Jays93XLT
ABB Yeah, I tightened the slack adjusters (wasn't sure what they were called) and all the springs are back on. Front calipers were $18.99 ea. plus $12 ea. core charge so I'm going to replace my old rusted out one's anyway. Stupid me I didn't take the cap off of my MC and I probably blew a seal. So, what was supposed to be a $60 job (pads and shoes) is going to end up being a $150 job (pads\shoes, calipers, and new MC).
Old Jun 3, 2004 | 09:03 PM
Abigbronco's Avatar
Abigbronco
Let us know if it works for you.
At least domestic parts are alot cheaper than import parts.
If it were a toyota it would be a $300 job. At least.
Old Jun 3, 2004 | 09:41 PM
Jays93XLT's Avatar
Jays93XLT
Very true. Thanks, will let you know.
Old Jun 5, 2004 | 07:55 PM
Jays93XLT's Avatar
Jays93XLT
The master cylinder was totally shot, replaced it and brakes are good as new.
Thanks for the suggestions.
Duckmang
Jul 3, 2013 01:13 AM
connork
Mar 24, 2013 06:52 AM
eldo
Escape & Escape Hybrid
May 24, 2005 12:00 PM
mwc4275
Aug 18, 2002 10:17 PM
